04-13-2013, 11:31 AM | #1 |
Newbie Join Date: Apr 2013 Location: under the highway
| driveline sq33k
since first day i pulled hocho out of box it had a awful squeak, it sounds like its in the shafts but i cant pin point it, axial support wasnt much help, they said maybe the diff oil is shot already, but ive had the truck for a week. does oil go bad that fast? or im thinking maybe its the shafts... any help would be awesome! |
04-13-2013, 12:00 PM | #2 |
Rock Crawler Join Date: Jul 2012 Location: Grand rapids
| Re: driveline sq33k
I've had mine for a while and about 9 months ago I got the same issue, I've greased everything swapped out bearings and it still does it lol I'm at a loss
04-13-2013, 12:05 PM | #3 |
RCC Addict Join Date: Feb 2012 Location: UK
My stock motor squeaks out of the box.
04-13-2013, 12:46 PM | #4 |
Newbie Join Date: Mar 2013 Location: Graham
My rubi squeaks sometimes but.... its a jeep so I assumed it was normal lol Sent from my iPad using Tapatalk HD |
04-13-2013, 03:30 PM | #5 |
Rock Crawler Join Date: Oct 2012 Location: Casper
| Re: driveline sq33k
I had the same squeak in mine. When I installed my VP dig I discovered that the screws holding the output shafts, inside the transmission, had almost come all the way out, and had been rubbing on the trans housing. Might want to tear into your transmission with loctite handy.
04-13-2013, 03:56 PM | #6 |
Newbie Join Date: Aug 2012 Location: Australia
| Re: driveline sq33k
I had this issue to and hit the drive line joints with some WD40 fixed it right up.
04-13-2013, 04:41 PM | #7 |
Quarry Creeper Join Date: Jul 2010 Location: Canada
| Re: driveline sq33k
might want to go back and hit them again with a lubricant this time.
04-13-2013, 07:39 PM | #8 |
Rock Crawler Join Date: Apr 2011 Location: British Columbia
| Re: driveline sq33k
Yea the plastic driveshafts squeek alot, it's because the metal yokes turn and put pressure on the plastic shafts
04-13-2013, 07:41 PM | #9 |
| Re: driveline sq33k
Try metal driveshafts
04-14-2013, 09:25 AM | #10 |
Newbie Join Date: Apr 2012 Location: Somewhere in Vancouver
| Re: driveline sq33k
Its your drivelines. Try clocking your axle just a little. To create less angle at the joint. Common out of the box issue. I work at a lhs and this is always one of the first things people complain about.
04-19-2014, 11:58 PM | #11 |
Pebble Pounder Join Date: May 2012 Location: STRONGSVILLE
| Re: driveline sq33k
Year old thread I know. Just replying to really help clarify this. It's the universals all day. Just built my wrangler kit and drive it one time. By the end of the run it was driving me mad how much it was squeaking. It's only on power when it's moving. Not when you turn the wheels by hand. Hit up the joints with some trinity bushing oil and noise gone. I'm sure everyone has a different answer due to their specific case of something rubbing or grinding. But this is a common issue that I've experienced on all 5 axial vehicles I've owned. It's the joints, it's a regular maintenance part, you need to clean them and oil them just like a real truck |
driveline sq33k - Similar Threads | ||||
Driveline?? | rocknut36 | Formula Offroad | 20 | 05-18-2011 10:31 PM |
driveline | yfz350 | Axial AX-10 Scorpion | 0 | 02-08-2010 08:19 PM |
Driveline | TBex | General Crawlers | 9 | 11-05-2009 09:36 PM |
driveline | mini max | Axial AX-10 Scorpion | 3 | 06-14-2009 11:50 PM |
