04-15-2013, 06:14 PM | #1 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
| need some input
I bought a used SCX10 and made it a long wheelbase so I could put a honcho body on it. the question is the truck has a Hand Brothers servo frame mount, with a hard pan kit, so if take the frame mounted servo off. and mount the servo on the axle do I need to remove the hard pan kit, the only reason I would move the servo is to mount the battery plate up front to get the honcho body to fit, cause I don't want to cut the body to clear the battery plate, that is currently mounted in the back. the servo mount is kinda high, so putting the battery tray over it is out, I got 7.4 volt 5000 mAh lipos that are big batteries so need to mount it some how.
04-15-2013, 06:26 PM | #2 |
Pebble Pounder Join Date: Jan 2009 Location: THE OTHER STATE OF MAINE
| Re: need some input
I would remove the pan hard mount if you move the servo to the axle and run a four link in the front or three link. but before you do you could consider mounting the battery side ways over the frame rails in front of the motor or depending on battery size you could cut out a L shaped plate and mount it around the chassis mounted servo and run like a 1550mah 2s or 3s next to the servo. I did that on my last honcho and i am currently building another and plan on running 4000 or 5000 mah 3s and will mount a battery plate cross the frame like I mentioned.
04-15-2013, 08:33 PM | #3 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
| Re: need some input
Mount the servo in the stock location on the axle. Move the battery tray to the front, and mount it as low as possible ,it should clear. I've got a 6500 mil amp lipo in my scx10 basher that fits.
04-15-2013, 11:27 PM | #4 |
| Re: need some input
I got screwed the guy ground and cut off the servo mounts on the axle, so now I got to buy axle housing, with the mounts, or buy a servo frame mount, I seen one that mounts in across the front of the frame right behind the front bumper mount, and is low enough to mount the battery tray over the top of the servo, not sure where I seen it or brand, going to buy a four link truss and four link the front. not sure how to mount the servo yet. any input would be very helpful thank you.
04-16-2013, 03:50 AM | #5 |
Newbie Join Date: Oct 2012 Location: @work
| Re: need some input
were the mounts cut off the rear axle? just swap front and rear?
04-16-2013, 01:34 PM | #6 |
Quarry Creeper Join Date: Mar 2009 Location: Torrance, CA
| Re: need some input
Why not just buy a smaller battery and mount it next to the servo?
04-16-2013, 01:37 PM | #7 |
| Re: need some input |
04-16-2013, 03:38 PM | #8 | |
Newbie Join Date: Apr 2013 Location: Portland
| Re: need some input Quote:
04-16-2013, 05:07 PM | #9 |
Rock Crawler Join Date: Jan 2012 Location: Champlin, MN
| Re: need some input
on both axles? you could switch the front and rear around if the rear isnt ground. otherwise there is https://www.google.com/shopping/prod...ed=0CF4Q8wIwAw Cheap stock replacement options. |
04-17-2013, 12:41 AM | #10 |
| Re: need some input
some one ground the servo mounts off both axles, but that's ok, I could replace axle housing, but still would only get two mounting holes for servo plate cause the third one is in the stock three link truss, I bought a aluminum four link truss, and a new aluminum servo frame mount, the turns the servo sideways right where the front bumper mount, goes into the front, under the battery tray, don't know i'm new here can I post pics right away or do I have to wait, cause I'll will post pics when the parts come in and after if people would like. so this centers the servo, so can I make a suicide steering system like the one I say for a wraith. and use two arms in stead of the one stock one. running 1.9'' no neede too go to 2.2 got two wraiths, want to keep the scx10 close to scale.
04-17-2013, 10:17 AM | #11 |
need some input - Similar Threads | ||||
I need Input | sobe164 | HPI Wheely King | 5 | 04-23-2009 04:46 PM |
anyone got some input? | moe68 | Paint and Body | 17 | 02-23-2007 12:49 PM |
Need some input | BlueMonster | Electronics | 3 | 12-09-2006 05:01 AM |
