04-21-2013, 07:47 PM | #1 |
Pebble Pounder Join Date: Aug 2009 Location: Orygun
| wroncho burning up motors
I have a wroncho with 2.2 swampers and stock wraith electronics and for some reason it keeps roasting motors any input?
04-21-2013, 08:04 PM | #2 |
Pebble Pounder Join Date: Feb 2009 Location: wilkeson
What gear is in it?? Stock is 80/20 |
04-21-2013, 08:13 PM | #3 |
| Re: wroncho burning up motors
That's what it is
04-21-2013, 10:02 PM | #4 |
I think my motor is getting pushed into my spur from the nut holding the upper link any solutions?
04-21-2013, 10:09 PM | #5 |
Pebble Pounder Join Date: Mar 2013 Location: Honolulu
The motor getting rubbed by your upper link shouldn't be a big deal. With those big heavy tiers you should gear way down. Try a 15t or 16t pinion. With the high 20/87 stock gear ratio the motor gets pretty hot already. Once you start adding weight/tires etc your motor will thank you when you gear it down.
04-21-2013, 10:17 PM | #6 |
The nut pushes the motor sideways into the spur so there is a lot off stress
04-22-2013, 01:26 AM | #7 |
RCC Addict Join Date: Feb 2012 Location: UK
My Wraith ate through cheap motors when geared 80/20 and crawling...Just too high. 87/14 was great. I'm running the same gearing in my SCX10 now. I could probably go up a little on the Pinion. So much torque it sound more like a power drill than a truck. |
04-22-2013, 08:00 AM | #8 |
It will make a motor smoke and melt the wires together after 5 min on the pavement
04-22-2013, 08:44 AM | #9 |
If you remove the motor does it roll freely without any major binding?
04-22-2013, 09:44 AM | #10 |
I haven't tried yet I need to do a dissection and see where the problem is
wroncho burning up motors - Similar Threads | ||||
Burning up motors | SNOWYOTA | Electronics | 29 | 04-03-2013 08:31 PM |
Burning up motors | 51JeepWillys | Axial Wraith | 17 | 03-21-2013 08:20 PM |
Burning up MOtors HELP | Pegasix | Electronics | 21 | 05-19-2012 04:19 PM |
Keep Burning Motors | Playa92687 | Electronics | 4 | 05-08-2012 04:48 PM |
why am i burning up motors?? | hoghead5150 | Axial Wraith | 52 | 11-08-2011 07:19 PM |
