04-22-2013, 07:37 AM | #1 |
Rock Stacker Join Date: Dec 2011 Location: Rosenberg
| Taking tires off stock rims
I ordered some rims for my rtr rubcion and was curious how I can get the tires off the rims. I also plan on cutting my foams. Eventually I'm gonna change to a different tire, but for now I'm gonna stick with the stock tires. Thanks!
04-22-2013, 08:06 AM | #2 |
RCC Addict Join Date: Sep 2011 Location: Peoria, AZ
| Re: Taking tires off stock rims
Asked many times but if you do a search you will find it., But here it is off of Harley thread hope this helps you out Bro...... 2 tires successfully dismounted! Place 2 tires on cookie sheet covered with tinfoil. Preheat oven to 325 Bake tires for 30 minutes. Remove tires from oven, leave on cookie sheet. With oven mits or protection of some sort, break the tires off the bead on the side facing up. Flip the tires over and place back in the oven for 10 minutes. Remove from oven and finish removing the tires from the wheels. EASY! Please be careful! I had some water in my tires and the steam that was coming out could have been pretty dangerous. |
04-22-2013, 08:19 AM | #3 |
I read something about that, was hoping there was another way lol. Anyone know if it makes the house stink?
04-22-2013, 05:06 PM | #4 |
RCC Addict Join Date: Feb 2012 Location: Ca.
I boiled my Rubi tires and wheels in a large pot of water. It took a long time to get them to break loose but it finally happened. The oven trick sounds as if it would be faster. And yes, you can smell the rubber when it gets hot.
04-22-2013, 09:13 PM | #5 |
Quarry Creeper Join Date: Mar 2009 Location: Grande Prairie, AB, Canada
I will warn you. Do not use your wifes good cookie sheet and do not do in the house when she is gone. She will smell it when she get home, even 12 days later. I would suggest finding an old microwave oven at a second hand store and doing it out side. Sent from my GT-I9100 using Tapatalk 2 |
04-23-2013, 06:08 AM | #6 |
Looks like I'm just gonna be buying new tires lol
04-23-2013, 06:37 AM | #7 |
Quarry Creeper Join Date: Feb 2011 Location: The underground
Wrap in tin foil turn oven to 325 set time to 30 min turn off oven leave in oven for 2 hrs Remove tires from rim without damage Go have a beer! |
04-23-2013, 07:13 AM | #8 |
RCC Addict Join Date: Feb 2012 Location: UK
I'll convert 325F? to C and have a go. I need to remove some tyres soon too!
04-24-2013, 06:51 AM | #9 |
Pebble Pounder Join Date: Sep 2012 Location: Rockford
I soaked stock wraith tires and wheels in acetone over night and they came right off very easily. Sent from my iPhone using Tapatalk |
04-24-2013, 08:33 AM | #10 |
Newbie Join Date: Apr 2013 Location: Calgary
+1 on the acetone, i use something disposable that i can lay my tire in, but doesn't have much depth and have just enough acetone to cover where the glue would be. I also weight down the middle of the rim so that it touches the bottom of the container so i don't have my whole tire and foams soaking in acetone. It takes quite a while but it comes off smooth, little to no glue left over and I haven't had any issues after the fact
04-24-2013, 06:23 PM | #11 |
How long do you have to let them sit in the acetone? Its been an hour and I'm getting impatient lol.
04-24-2013, 06:36 PM | #12 |
Rock Crawler Join Date: Dec 2011 Location: thurmont
| Re: Taking tires off stock rims |
04-24-2013, 06:49 PM | #13 |
Rock Crawler Join Date: Sep 2012 Location: Roxborough, CO
The above is a great vid - watch it! And +1 to the acetone - hands down IMO the best way to do it - did it that way on last set of factory glued treps I bought off classifieds here and will do it that way this point forward. |
04-24-2013, 06:54 PM | #14 |
I let them sit for 2hrs, went to check on them, and the seam was already starting to break. I applied a lil pressure and they popped off. Got them all off! Thanks!
04-24-2013, 07:06 PM | #15 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
i used a blow dryer to get mine off took a little while
04-25-2013, 06:55 AM | #16 |
I let mine sit overnight in an empty paint can with the acetone. They pretty much fell off the rims the glue was completely gone. Sent from my iPhone using Tapatalk |
Taking tires off stock rims - Similar Threads | ||||
what tires fit on stock rims? | ninetwofiveRC | Venom Creeper | 5 | 12-14-2010 11:46 AM |
What all does it take to get stock high lift tires and rims to a stock tlt axle? | bi_eep | Newbie General | 5 | 01-18-2007 10:54 PM |
Dual rear tires, using stock tires and rims. | Pig Pen Jr. | General Crawlers | 3 | 10-05-2006 07:31 AM |
