04-22-2013, 10:41 PM | #1 |
Pebble Pounder Join Date: Nov 2012 Location: imperial
| scx10 Mojave Hilux Build
SCX10 $355.98 http://www.rpphobby.com/Axial_Trail_H... Futaba 4PL $250 http://www.rpphobby.com/SearchResults... Hitec High-Voltage Mega Torque HS-7950TH Digital Throttle Servo w/ Titanium Gears $150 ht217 Gear Head RC SCX10 Rear Shock Relocation Kit $20 http://www.rpphobby.com/product_p/gea... Castle Creations BEC 10A Switching Regulator $20 putting out 7.4 volts for High Voltage High Torque Steering Servo http://www.rpphobby.com/product_p/cse... Castle Creations Castle Link Programming Kit $21.99 http://www.rpphobby.com/product_p/cse... Holmes Hobbies BRXL with Motor Combo $156.99 (added waterproofing for $10) TorqueMaster Pro combo (Rated best by RCCrawler.com) http://holmeshobbies.com/TorqueMaster... Hot Racing Shocks $40 (2 pair) http://www.rpphobby.com/product_p/hot... 1.55 RC4WD Rock Stompers $50 (2 pairs) http://www.rpphobby.com/product_p/rc4... RC4WD Stamped Steel 1.55 Stock Beadlock Wheel White (4) $40 http://www.rpphobby.com/product_p/rc4... RC4WD Complete Mojave Body Set for Trail Finder 2 (Primer) Mojave Hard Body $110 http://www.rpphobby.com/product_p/rc4... RC4WD LED Lighting System For Mojave Body Set $18 http://www.rpphobby.com/product_p/rc4... HeyOK Remote Switch for LED Lighting $20 http://www.rpphobby.com/product_p/hey... GENS ACE 5000mah 3S1P 11.1V 40C hard case Lipo battery Racing Approved Batteries $60 Shop for RC Hobby Parts and Upgrades - Digital Servos, Brushless Motors, ESC, LiPo Batteries/Chargers for RC Helicopters, RC Planes, RC Cars, Robots... Scale Bench Seat for Mojave Body $20 http://store.rc4wd.com/Scale-Bench-Se... Custom Length 4 Link and Steering Linkage $20 (the brake Tubing and all thread trick) Lowes Hardware Store Total Price: $1353 (adding up the above) + a $300 gopro Silver addition making a total of $1653 invested. |
04-22-2013, 10:45 PM | #2 |
Rock Crawler Join Date: Jan 2013 Location: Laguna Niguel
| Re: scx10 Mojave Hilux Build
Really great!
04-22-2013, 10:53 PM | #3 |
Thank you! I just realized the links do not work. I'll try it again. SCX10 $355.98 Trail Honcho 1/10th SCALE ELECTRIC 4WD - RTR Futaba 4PL $250 RPP Hobby | Radio Controlled Cars, Trucks, Boats, Helis, Planes, Plastic Models Hitec High-Voltage Mega Torque HS-7950TH Digital Throttle Servo w/ Titanium Gears $150 ht217 Gear Head RC SCX10 Rear Shock Relocation Kit $20 Gear Head RC SCX10 Rear Shock Relocation Kit Castle Creations BEC 10A Switching Regulator $20 putting out 7.4 volts for High Voltage High Torque Steering Servo Castle Creations BEC 10A Switching Regulator Castle Creations Castle Link Programming Kit $21.99 Castle Creations Castle Link Programming Kit Holmes Hobbies BRXL with Motor Combo $156.99 (added waterproofing for $10) TorqueMaster Pro combo (Rated best by RCCrawler.com) Holmes Hobbies LLC Hot Racing Shocks $40 (2 pair) Hot Racing Black internal spring air shock 100mm 1.55 RC4WD Rock Stompers $50 (2 pairs) RC4WD Rock Stompers 1.55 Offroad Tires RC4WD Stamped Steel 1.55 Stock Beadlock Wheel White (4) $40 RC4WD Stamped Steel 1.55 Stock Beadlock Wheel White (4) RC4WD Complete Mojave Body Set for Trail Finder 2 (Primer) Mojave Hard Body $110 RC4WD Complete Mojave Body Set for Trail Finder 2 (Primer) RC4WD LED Lighting System For Mojave Body Set $18 RC4WD LED Basic Lighting System For Mojave Body Set HeyOK Remote Switch for LED Lighting $20 HeyOK Remote Switch for LED Lighting GENS ACE 5000mah 3S1P 11.1V 40C hard case Lipo battery Racing Approved Batteries $60 GENS ACE 5000mah 3S1P 11.1V 40C hard case Lipo battery Racing Approved Batteries Scale Bench Seat for Mojave Body $20 Scale Bench Seat for Mojave Body And here's a Youtube video! https://www.youtube.com/watch?v=ilM8DefeIfs |
04-22-2013, 10:58 PM | #4 |
Also, I've found an awesome and very easy way to accomplish 2 things ...1) Mount a 5000 mah battery under this hardbody (sideways) and mounting the body using things you already have and the existing holes in the Mojave body. I will post these pics tomorrow. Hopeully these 2 things will help people as I have not seen these done on this forum. OK so a couple of interesting things to note about the tire selections I've made. Those are actually 1.55 Rock Stompers and 1.55 steel rims (not 1.9). I totally agree that 1.9 or in my case the 1.55 look so much better. It's way more scale than 2.2 tires! The way the body sits on the truck lowered against the 1.55 wheels is what really sets these scaler trucks apart from others. In my search for the "perfect" tire I utilized this Scale Tire Size Charts... This link shows the tire sizes. When you purchase the "Mojave" or "Hilux" hard bodies, you have to be really careful about tire sizes. The 1.55 Rock stompers are a very scale looking tire in looks and in dimensions. The 2nd tire I've chosen "just for fun" is the Flat Irons 2.2. You'll notice from the tire chart that Flat Irons 2.2 are one of the "widest" tires out there. And they are still a shorty diameter tire. Bottom Line, they work very good on the scx10 and Mojave hard body combination. No need to cut the hard body. I promised to post some pics on how I mounted the Mojave hard body on the scx10. Check out the photo. You already have the parts to do it. I tried everything and this is the best way! You do not have to cut more holes in your new hard body. The rear comes pre-drilled. You'll want to use these existing holes and "not" cut new holes on your body. The way below allows this. Just let me know if you have questions. My goal here is to let others know as this is so simple and I have not seen it done before. This will also allow you to quickly adjust the body to any position you would like (so you can use 2.2 tires or 1.9 / 1.55). Yes, this body is not painted. If you look carefully, I've added small details to it without painting the body. I liked the color just how it came. The primer color is awesome. Don't get me wrong, painting is fun and I'll do it sooner or later. But for now, I've ran with detailing the bed "black" and other parts of the truck with black trim. I'm adding the "black" toyota graphics to it soon as well. The other neat trick you can do with a scx10 and a Mohave hard body is mount the battery sideways. The only way to maintain the low body look against the 1.55 tires is to mount sideways. In my case, I went to the extreme and I'm using a 5000 mah Lipo (big battery!), and mounted it sideways. This truck has pure power! It's a "sleeper". So the battery lies "just perfect" between the chassis and the body and that's with the bench seat also installed. I even mounted the gopro holder on top of the battery. So this is proof it can be done. And then you just mount everrything else (the receiver box) on the front where the battery used to be. This does 2 things. Moves a heavy lipo battery 2 inches for the best center of gravity you can get! And raises the electronics to keep them out of 4 inches of water. Here's some more pics. Enjoy, please let me know if ya have questions. Last edited by THX_138; 06-06-2013 at 12:28 AM. |
04-23-2013, 07:50 PM | #5 |
Pebble Pounder Join Date: Mar 2013 Location: Honolulu
The 1.9's look sooo much better! The 2.2 are an eye sore! Is the body painted grey or is that the color of the plastic? |
04-23-2013, 09:39 PM | #6 |
| Re: scx10 Mojave Hilux Build |
04-23-2013, 09:41 PM | #7 |
04-23-2013, 09:45 PM | #8 |
04-23-2013, 10:02 PM | #9 |
Tires are 1.55 Rock Stompers.. they fit so good to get the low look (scaler look). I put the 2.2 flat irons on there just for fun (widest / shortest combo you can get). The tire looks awesome when scrunched down from the weight of the truck. The 1.55 tires I must say fir the hard body very nice (scale looking). 2 other things while I'm thinking of it. Best place to buy a scale driver is Toys R Us. And for get about mounting magnets to hold the hard body on. Clips is the only way to do it. Otherwise the body will fall off. You want you hard body to be mounted nicely so it does not fall off so for gosh sakes use the clips, it does not look bad. Anf finally the hot racing shocks are the most scale and best working scaler shocks I have ever used! If you type "hot racing" shocks into the search button you'll get mixed reviews. Take it from me...they work awesome. Not one complaint...period. Make sure and buy the 100mm ones (not 90 and not 110). Black is an awesome color and the thick shafts make all other scale shocks just look flimsy.
04-23-2013, 10:04 PM | #10 |
Quarry Creeper Join Date: Jul 2010 Location: Canada
you got the body down a little lower. looks great!
04-23-2013, 10:09 PM | #11 |
04-23-2013, 10:09 PM | #12 |
04-23-2013, 10:14 PM | #13 |
Thank you! appreciate that. And that's with a 5000 mah battery sitting sideways in it w/ the 1.55 tires!
04-23-2013, 10:19 PM | #14 |
yup looks great I did my hilux honcho the same way. its the perfect spot for the battery. |
04-24-2013, 09:14 PM | #15 |
very nice! Thank you for sharing this.
04-24-2013, 11:08 PM | #16 |
My pleasure, I hope you enjoy your lux. I liked the vids too btw.
04-25-2013, 04:44 AM | #17 |
Rock Stacker Join Date: Dec 2012 Location: Guam
Great looking rig man now let's see it get dirty
04-25-2013, 07:58 PM | #18 |
Will do. I'm gonna try and run this through some serious mud this weekend. My goal is to make an awesome gopro vid.
04-28-2013, 09:03 AM | #19 |
Well, I did not make it outside today but I did mount the gopro to various positions on the truck to see what it would look like in a video. See below! Let me know how I did with the video. I'm not the best at video editing but gave it a shot. Figured, I'd also show the mounting positions with some pics. |
04-28-2013, 09:18 AM | #20 |
scx10 Mojave Hilux Build - Similar Threads | ||||
Jhop1 scx10 mojave body build | jhop1 | Axial SCX-10 | 24 | 12-03-2014 07:36 AM |
hilux cab mojave bed ? | stephen77423 | Paint and Body | 1 | 01-13-2013 07:30 PM |
Hilux parts or Complete Mojave set? - SCX10 Trail Honcho | Jake1715 | Axial SCX-10 | 0 | 07-19-2012 05:09 PM |
