06-24-2013, 11:07 AM | #21 |
Pebble Pounder Join Date: Jan 2013 Location: Zürich
I dont think that there is a must have... It all depends on your needs. If you dont have a huge budget, drive the car and replace whatever brakes with an upgraded spare part... I also bought the RTR a while ago and started my first upgrade by buying a new servo. |
06-24-2013, 11:50 AM | #22 |
RCC Addict Join Date: Feb 2012 Location: UK
| Re: "Must have" upgrades for SCX10 Jeep Wrangler Unlimited Rubicon RTR
I used my high end Hitec Servo from the off (With BEC). The soft steering links were being bent in every way....Sooooo....I added the Aluminium links. The torque of the servo would cause the knuckle to bend and eventually this failed. Soooo Aluminium knuckles....Now the extra strain goes through the upgraded links to the upgraded knuckles and the stock C-hubs flex and bend. :( Haha....
09-15-2013, 02:13 AM | #23 |
If you all really paid attention to the new Axial Jk kit I must say is it just me or has Axial beefed up theor plastic? I held a first release knuckle next to a brand new one and the old knuckle seemed to be very stiff almost fragile to a point I know it will snap if hit hard enough. The new one off the JK kit seems a little more forgiving and slightly beefier in compound. I also noticed the scx10 skid seemed more robust as well. Unfortunately they did the sesame thing a with the wraith kit and left plastic upper links!!! Why?!! its sure is fun to build another scx10 now that I have built 4 of them already and the only true scx10 left is a hard bodied Tamiya tundra. Everything else has custom chassis or moved on to another owner. This one will be a spare parts build since Corey had that axial sale for 300 I said why not?! |
09-15-2013, 10:53 PM | #24 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
Im pretty new to this rock crawling /trail truck scene but now own 2 axial products..the honcho and the rubicon unlimited. Its recommended to move the battery to the front..Its just not as capable climbing wise as the honcho is with all the weight to the rear. The second thing ive noticed is the stock maxxis trepador tires just don't have the grip the ripsaw tires have on the honcho...they are taller but much narrower..On sufaces I play on (grass/dirt/rock) there is no comparison to the ripsaw tires. One thing ive noticed is the stock 27 turn motor wth a 2s lipo is more than enough power to do anything you want with the truck. I run a 17 tooth pinion on my stock 27 turn motor and torque is plentiful..It slowed down alittle top speed wise but still gives good wheel speed to get you through that mud or a running start on a difficult hill. When you start going with these super torque motors and more powerful batteries you will start breaking things and then your toy becomes a money pit..aluminum this and steel that just equals big money and you have to spend more for a better esc and and a 3s battery and super hi torque servos to get your performance back..Dont fall into that money trap..Your rig is plenty capable with just a few strategic mods. So I leave you with a list of what ive found to be solid upgrades in my opinion and maintain the great performance without breaking the bank. Move battery to the front (rubicon unlimited) 2s lipo battery ( I use a 4000mah and get well over 1hr of run time.) 17 tooth motor pinion.( reduces overall speed but increases low speed torque) Axial ripsaw 1.9 tires/stock wheels (amazing traction) Last edited by 6sharky9; 09-15-2013 at 11:29 PM. |
09-16-2013, 07:06 AM | #25 |
Quarry Creeper Join Date: Apr 2013 Location: SE PA
the only "must have" upgrade, at least in my mind, are m3 screws going thru the knuckles and into the Chubs. maybe mine was old or they just used scrap parts for another car but the self tappign screws that came in there on my scx-10 (and the ridgecrest I bought rtr) tend to back out alot and can break the chubs and knuckles as well as potentially damage the dog bones. after that both became extremely reliable trucks. still running mostly stock parts in my ridgecrest, still running what ever parts came in my bucket o parts that became my scx-10. most of it looks stock but it does have annoyingly green links everywhere. |
09-16-2013, 12:44 PM | #26 | |
Rock Crawler Join Date: May 2011 Location: Cali/Korea
Hes right for the most part but if u want it to perform better the stock electronics will need to go. The motor doesnt have the balls to hang and hike real trails all day. They are fun and work great for light use but will last nowhere near a holmes motor and or have the torque and crawlability . I keep an axial as a spare and run the strong stuff. Nothing like getting to the top of a trail on a beautiful weekend and having ur motor take a poop on u. Lik Sent from my SHV-E310L using Tapatalk 2 Last edited by OFFROADRCKOREA; 09-16-2013 at 12:46 PM. | |
09-24-2013, 10:12 PM | #27 |
The SCX10 kit now has definitely improved on their plastics. I am in the process of building a third SCX10 this is the JK Rubi version and not only are the stock plastic knuckles, hubs, skid, shock hoops, definitely the aluminum shocks now despite plastic caps!!! And still the same old plastic balls Axials use not too shabby. I am going to run my OG 1st generation SCX10 front axle with a new underdrive rear axle and do a comparison. This rig will be a budget rig no fancy bells or whistles....or so I say lol. Must have upgrades you can either do the XR mod, VP VVD's. Axial CVD's, or just stick with doggie bones. All depends on how you drive really. I'd just replace what breaks first and usually its the drivelines or the plastic idler gear. |
09-24-2013, 11:04 PM | #28 | |
| Re: "Must have" upgrades for SCX10 Jeep Wrangler Unlimited Rubicon RTR Quote:
Ive seen a nearly 100 percent stock honcho out trail and climb some high dollar rigs..the high dollar rig did look good though. These are mods I did to my rubicon and its very impressive. Home made Aluminum Lower links and steering links Removed the rubber stops on the shocks Moved the shocks to the farthest holes toward the center of the truck Robinson 17t pinion/ Kimbrough 87t spur Custom 27t brushed motor GensAce 4000 mah 2s lipo Stock honcho wheels and ripsaw tires Re-located battery to the front like the honcho. All else stock as of now. (Duplicate of my honcho minus the body) Next on the list of mods: Universal front axles and shocks..Also relocation of battery and electronics...This should conclude my build :p My next future project will be a Dingo :P Last edited by 6sharky9; 09-24-2013 at 11:13 PM. | |
09-24-2013, 11:11 PM | #29 |
Newbie Join Date: Jul 2013 Location: GB
I agree with most people, just drive it stock and fix as it breaks. Only thing I would get would be a lipo.
10-26-2013, 04:18 PM | #30 |
Newbie Join Date: Jun 2011 Location: Vienna
I bought a Rubicon a couple of days ago and here are my mods so far: 1) Placed battery where ESC was -> ESC moved above the servo 2) Stiffen up steering link with carbon rods 3) Added some lead weight inside the rims of rear wheels -> about 60 gramm per wheel 4) removed the rubber stops on the shocks So far I am pretty happy with the performance. |
10-27-2013, 02:27 PM | #31 |
Yesterday I also installed the 4-Link suspension in the front. All the parts except screws come with the parts tree. Really like it! Also I will make some aluminium links soon. I think there are no "must have upgrades" but everything that improves performance and durability is nice to have. |
11-03-2013, 03:00 AM | #32 | |
Newbie Join Date: Sep 2013 Location: Carson
You Are supposed to add weight to the front tires, not the rear. | |
11-03-2013, 06:22 AM | #33 | |
I also build some aluminium steering links. Very sweet. http://www.youtube.com/watch?v=DN3_MOjyWuo | |
11-03-2013, 07:02 AM | #34 | |
Quarry Creeper Join Date: Jul 2013 Location: Meridian
I agree...I am new to the scale scene, but drive almost daily and did two G6s, drive as is....you have a great rig. My upgrades have been a winch from RC4WD, bead lock rims, vanquish light bar. I did replace the drive shafts with the Axial upgrade because mine were beat pretty bad. Also sand ladders, tow rope, pull pal, and scale items. The family and I "club spec" in terms that no one of us does a performance up grade unless all of us do the upgrade or at least has the option to....so a $100 for a part cost me $300. Esthetic items are fair game and we are constantly adding for fun, folly, or to meet G6 optional item list. My next move will be towards water proofing all electronics and moving the battery to the front. | |
02-17-2014, 02:07 PM | #35 |
Newbie Join Date: Feb 2014 Location: New York
Upgrade the steering servo, the stock one sucks big time and follow the rest steering link and so forth
05-18-2014, 06:08 AM | #36 |
Newbie Join Date: May 2014 Location: burrows
I ugraded my scx10 with 2.2 ripsaw tires and it totally changed the look , it went from cool to awesome, also added new aluminum shocks .......relocating the battery to the front was the first thing I did and it made a world of difference
05-18-2014, 10:08 AM | #37 | |
Pebble Pounder Join Date: Mar 2014 Location: Vancouver
I must have missed some parts in my box or they didn't ship them but I looked all over so I could build my unlimited with 4 link in the front. The only parts in there were the upper links. No 4 link truss to be found anywhere on any parts tree. Am I missing something or does the unlimited rubi not have the option supplied with the kit? Sent from my iPhone using Tapatalk | |
05-18-2014, 10:17 AM | #38 |
should be on the patrs tree.
05-18-2014, 10:25 AM | #39 |
Quarry Creeper Join Date: Dec 2009 Location: West Alabama
I just built a kit. Only comes with 1 4-link truss Sent from an SG3-Mini |
05-18-2014, 10:28 AM | #40 |
| Re: "Must have" upgrades for SCX10 Jeep Wrangler Unlimited Rubicon RTR I got the RTR. Comes with one installed and one on the patrs tree.
"Must have" upgrades for SCX10 Jeep Wrangler Unlimited Rubicon RTR - Similar Threads | ||||
Bender's SCX10 Jeep Wrangler Unlimited Rubicon | BENDER | Axial SCX-10 | 110 | 02-10-2015 08:10 PM |
Axial SCX10 Jeep® Wrangler Unlimited Rubicon | jason | Scale Videos! | 16 | 11-03-2013 09:27 AM |
SCX10™ 2012 Jeep® Wrangler Unlimited Rubicon | HyperMark | Axial SCX-10 | 0 | 10-30-2012 08:07 AM |
Operation Black Ops: "Behind Enemy Lines" Part 1 Axial Jeep Unlimited Rubicon JK | LetsGoMuddin | Scale Videos! | 2 | 06-02-2012 11:27 AM |
