04-29-2013, 04:10 AM | #1 |
Rock Stacker Join Date: May 2011 Location: quebec city
| crawlmaster pro 20t on a scx10
hi I want to know what you think as a driver in my SCX10 pinion and what do you recommend Site holmes hobbies he just say with a 16t , but I have in stock 14, 18 or 20 I want a bit of speed and torque I do not think I missed before I was riding with a 35t tekin hd whit a 20t pinion who passed away your opinion please thx a lot ps i have the motor here |
04-29-2013, 05:20 AM | #2 |
Rock Stacker Join Date: Dec 2008 Location: In the mud.
I run a 20T wraith motor in my honcho, its very fun driving and still a bit of torque. I run 20t/87t |
04-29-2013, 06:01 AM | #3 |
Pebble Pounder Join Date: Mar 2013 Location: Honolulu
| Re: crawlmaster pro 20t on a scx10
Are you running 3s lipo? Even if you are the 20t is going to be pretty slow. You have to remember the crawlmaster is a 5 slot Armature instead of the conventional 3 slot. The 16t would be closer to your old 35t tekin. It sounds like you like speed considering the 20 tooth pinion you were running. It's better to get a lower turn motor and gear down and volt up. I'd recommend a 13t crawlmaster and a 15 tooth pinion running on 3s. |
04-29-2013, 06:06 AM | #4 |
Sorry I think I misunderstood your post. Sounds like you have the motor already and are trying to decide between a 14, 18, and 20t pinion's. If that's the case I'd get the 18. |
04-29-2013, 08:42 AM | #5 |
Quarry Creeper Join Date: Dec 2010 Location: Alberta
HH recommends a 5:1 ratio.
04-29-2013, 10:12 AM | #6 |
Ok thx I run with 3s. I should be try between 18 and 20. Thx a lot |
04-29-2013, 11:35 AM | #7 |
Rock Crawler Join Date: Jan 2013 Location: Cen Cal
I'm not sure if the Tekin was really old and had served it's time, but maybe it had an early death from gearing it too high on 3s? If 5:1 is suggested and you have an 87 tooth spur then you need a 17-18 tooth pinion. If that 5:1 suggestion is for 2s operation then the ratio should be even higher for 3s (maybe 14-15 tooth). In any case gearing suggestions should only be thought of as a starting point and motor temperature should be the deciding factor because we are all in different climates and have different driving styles. If you run the 18-20 and it gets really hot put the 14 tooth on. If then you don't have the desired wheelspeed and the motor runs cool, try something like a 16 tooth. There's no sense in burning up a top dollar brushed motor from improper gearing. |
04-29-2013, 01:51 PM | #8 |
i have call a 16t pinion for sure but i pout the 14t before the 16t arrived thx a lot |
04-30-2013, 12:22 AM | #9 | |
04-30-2013, 04:08 AM | #10 |
i call 2 pinion lol< < 16t and 17t when i have it i can decided between the 14 16 17 or 18t i check the temperature ans put the good one |
crawlmaster pro 20t on a scx10 - Similar Threads | ||||
crawlmaster pro 540 | ax10 | Electronics | 5 | 12-14-2012 09:04 AM |
