04-29-2013, 05:29 PM | #1 |
Pebble Pounder Join Date: Apr 2013 Location: lowell
| wagon wheels on a scx10?
Kinda new to the crawling thing, do rc4wd wagon wheels fit a scx10 if you remove the hex drives? If so how much difference is there in width afterwards? Thanks for any help.
04-29-2013, 05:41 PM | #2 |
Rock Crawler Join Date: Jul 2012 Location: Grand rapids
| Re: wagon wheels on a scx10?
What style do you plan on doing then cuz my 2.2 have hex and my 1.9 have pin
04-29-2013, 06:00 PM | #3 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
you can buy the hex hubs to fit the rims the hex pin style will not work the hub hits the axle
04-29-2013, 06:05 PM | #4 |
Was looking to run the 1.9s, but they say they are pin drive.
04-29-2013, 06:15 PM | #5 |
Rock Stacker Join Date: Mar 2013 Location: La Serena - Chile
I bought the 1.9 and the hex adapters. tried on the honcho and the adapters got stucked in the honcho's hexes!! a very tight fit and i had to use some brutal force to remove them.
04-29-2013, 06:21 PM | #6 |
mine work just fine!!!!! all u need is the adapters that bolt the rims together in a hex.tore.rc4wd.com/OEM-Steel-19-Stock-Beadlock-Wheel-Hexes_p_1249.html this is all i bought when i got mine
04-29-2013, 06:24 PM | #7 |
04-29-2013, 07:26 PM | #8 |
Pebble Pounder Join Date: Dec 2012 Location: The fun house
I run RC4wd stamped wheels with .30 6-hole adpaters on my honcho. Stance is perfect IMO.
04-29-2013, 08:07 PM | #9 |
You got any pictures with the .30, wanting to get an idea how much farther they stick out.
04-29-2013, 10:55 PM | #10 |
Quarry Creeper Join Date: Nov 2010 Location: Sarasota, Florida
| Re: wagon wheels on a scx10? |
12-21-2013, 03:56 PM | #11 |
Quarry Creeper Join Date: Nov 2013 Location: alberta
I'm running the pin mounts on my scx10 with no rubbing issue
12-24-2013, 08:40 PM | #12 |
Quarry Creeper Join Date: Jul 2013 Location: Toronto
here are some pics of my G6 with the 6 lugs, i didnt think i would like them but they have grown on me |
12-24-2013, 09:00 PM | #13 |
Quarry Creeper Join Date: Apr 2013 Location: Upstate
Here is my go with some RC4WD Wagon Wheels 6 Lugged painted Matte black. They will be outfitted with 2.5M Acorns & Pro Scaler Hub tomorrow by lunch! Will add the newer pics, but this is basically stock offset with the TSL SX's mounted!
12-25-2013, 01:34 PM | #14 |
Newbie Join Date: Nov 2012 Location: Seacoast
| Re: wagon wheels on a scx10? I got some of these wheels for x-mas, but the rear axle nut is bottoming out before the wheel is tight so they flop around. The front tighten up just fine. Guess I'm going to have to get the hex adapters, these are the correct ones? 1.9" 5 Lug Steel Wheel Hex Hub |
12-26-2013, 12:05 AM | #15 | |
| Re: wagon wheels on a scx10? Quote:
12-26-2013, 04:42 AM | #16 |
12-27-2013, 08:50 AM | #17 |
Newbie Join Date: Jun 2013 Location: two harbors
I use the pins drive on my wheels w/o hexes. I put a bearing (same size as axle bearings) between the wheel and nut as a spacer. So when you mount the wheels it goes wheel bearing nut.
wagon wheels on a scx10? - Similar Threads | ||||
RC4WD Wagon Wheels | mann0mann | Tires and Wheels | 3 | 08-14-2008 12:27 AM |
