Thread: The Crawl Space "Rock Bull" Unimog. (pic heavy)
Old 05-23-2013, 07:01 PM   #21
Default Re: The Crawl Space "Rock Bull" Unimog. (pic heavy)
Originally Posted by special agent View Post
Ikaika what winch is that??
I use the RC4WD bulldog winch. I pulled it from the salvage pile just to get one on the rig before the G6.
The newest winches from RC4WD are 10 times better now than the older ones.
Heres a tech sub-thread on the new RC4WD winches. They are using a brass bushing and can seize or studder during operation, so its best to do a little preventive maintainance before install.
The case feels a bit thicker and its held together with hex hardware, still be careful not to strip out the screws or holes during disassembly/assembly
I used some 220 grit sand paper to smooth out and reduce the size of the spool stub just a little so it would spin freely in the bushing.
Put a dab of heavy grease on the stub, bolt it back together and she's good to go
Here's my quick addition to the chassis, D-mounts for the rear
Grab some 1/8" alum. flat stock. cut down to 10mm and however long you liken and a couple shackles.
Make a template for mounting screws, filed and buffed down to finish.
Install and now you have shackles to hook up all them other trucks that need a hand
The Crawl Space is offline   Reply With Quote
Old 05-23-2013, 07:31 PM   #22
if you could find the right size you could probably put a sealed bearing in there instead of a bushing
theloudone is offline   Reply With Quote
Old 05-23-2013, 07:36 PM   #23
Just stumbled on this thread. Definitely tied for my favorite rig from last weekend
I loved seeing you take the mog through that tight squeeze on the night stage (the one where I lost my snorkel). The mog is most certainly g6 approved.
bvrc is offline   Reply With Quote
Old 05-23-2013, 10:15 PM   #24
Looks great...it is amazing how real y'all make these look...great work!
germ is offline   Reply With Quote
Old 05-23-2013, 10:28 PM   #25
Thanks ikaika, we have a few a those winches. With extra parts and motors cause they never last too long, its now in the parts bin.
Thanks tatum
special agent is offline   Reply With Quote
Old 05-24-2013, 10:18 AM   #26
Rajah dat, I'm on the hunt for some today.
I wanted to show the "work with what ya got" method as well for those that build on a budget. I'll update with what I find and the source and part number
Thanks tatum
Anytime T, the winches can be hit n miss sometime, I think this most recent run is good to go, i did a dead lift test of the mog and it pulled right up
I still have the first bulldog winch I ever got installed on the 15lbs. poi pounda and its still running strong, same original motor and transmission.
Old 05-27-2013, 03:38 PM   #27
Took a weekend trip to check out a new comp spot and shot a couple pics of the Rock Bull on some awesome terrain, enjoy
Did manage to break the panhard mount at the axle, so I'll be fabbing up a beefier one this week and get ready for the rigs first real comp in a couple weeks
Old 06-10-2013, 01:27 PM   #28
Hey gang heres a quick update.
I've been lucky to get some more drive time with this rig and after some shock tuning its getting better and better.
Currently the truck sits at 8.5 lbs. with Traxxas big bores, 30wt in the front and 35wt. in the rear with Losi black springs all around.
Now time for the real test, a scale comp.
We haven't been running many scale comps lately so when the opportunity to run a weekend long event with Pro, Sporty and Scale comps at the world famous Red Rocks we jumped all over it
There were 4 courses designed and layed out by 666 and Turtle and they were great! A good start for the new drivers getting into comps and still some challenges gates through every course for the more experienced drivers. I ran class III because of the cut n chut pitbulls and dig in the truck, being a pro comp driver most of the time I'm used to hittin' switches during a run, but I only used the dig once on course 4
Thanks to iluvdrt for snappin pics
This one looks like the trucks got a mini wheelbase, lol.
This was a sharp breakover with a slight under cut, this is were the short 11.75" wheelbase helps to get on top of obstacles instead getting caught on the skid.
This is were the short wheelbase got me a slight off camber uphill ledge with ruts and a diff hanger cut with an O.B. and not enough room for the wide track width of the rig.
This was the only time I pulled line to winch,at least it made for a cool pic
Old 06-10-2013, 06:57 PM   #29
That thing is a work of art man! Congrats! Are you running the slash rear big bores all around?
509hooligan is offline   Reply With Quote
Old 06-10-2013, 10:14 PM   #30
The cut and shut pits look great on there. Reminds me a bit of the old 2.2 pits. It gives it quite a monster mog look. Awesome!
Desert Rc is offline   Reply With Quote
Old 06-10-2013, 11:04 PM   #31
Looks killer - love the tires.
doublej is offline   Reply With Quote
Old 06-11-2013, 01:55 PM   #32
Thanks man. I'm running the 4" big bores for E-maxx on all 4 corners.
I love'em, big and wide and hook-up like crazy
I do have a set of OG 2.2 pitbulls for TTCs
Tires are loaded with Crawler Innovations closed cell DD foam with sidewall tuning rings to fill them out
Old 06-01-2014, 09:38 PM   #33
Hey Ikaika!
I just stumbled on your rig - looks awesome dude! I'm now in the process to acquire another 'Mog again ...
Fumbles is offline   Reply With Quote
Old 06-02-2014, 04:40 PM   #34
Originally Posted by Fumbles View Post
Hey Ikaika!
Thanks Tony, its been super busy so this thread is in much need of an update with tech and pics
Old 06-02-2014, 05:32 PM   #35
Can't wait to see the updates!!!
Old 06-02-2014, 10:55 PM   #36
I want to see more.....
Postclanker is online now   Reply With Quote
Old 06-03-2014, 08:54 AM   #37
That's a good looking Mog, nice work!
HDMM is offline   Reply With Quote
Old 06-03-2014, 04:40 PM   #38
Ok ok ok, heres a little tease
Old 06-03-2014, 06:29 PM   #39
Another awesome Mog!
mudbeast2 is offline   Reply With Quote
Old 06-04-2014, 05:42 PM   #40
Default The Crawl Space "Rock Bull" Unimog. (pic heavy)
Freaking awesome pic!!!! AWESOME!
Also look at that steering travel !!!
Tags
4x4, axial, mog, scale, unimog
The Crawl Space "Rock Bull" Unimog. (pic heavy) - Similar Threads
"Shakedown" Comp @ The Crawl Space. Friday, Oct. 14th. The Crawl Space Colorado 16 10-15-2011 03:57 PM
Saturday, Oct. 1st. "Official" Grand Opening of The Crawl Space The Crawl Space Colorado 44 10-03-2011 09:50 PM
The Crawl Space "Run what you Brung" GTG - Nov 28, 2010 Rckcrwlr Pennsylvania 10 11-28-2010 07:42 PM
W.Pa.C. "The Crawl Space" Winter Series Finals - March 14th Rckcrwlr Competitions 4 03-13-2010 07:33 PM
"The Crawl Space" Indoor Trail and Comp Facility Rckcrwlr Chit Chat 9 11-28-2008 08:40 PM
