05-04-2013, 05:59 PM | #1 |
Newbie Join Date: May 2010 Location: Mid-west
| **SCX-10 Gear noise...PLEASE HELP!**
Hey everyone, Been awhile since I've been on here but anyway...so, I built a Honcho kit back in 2010 and from day one my truck has had a sloppy noise coming from the pinion/spur gear area....at first I thought it was the motor but I have removed the pinion gear and run the motor by itself and its really quiet, so then my next step: I disconnected the driveshafts from the differentials and it was still pretty quiet so I know it's not the transmission, so now I was unsure...but maybe it was the internals of the axle/gears inside the pumpkin...I decided to tear apart the axles anyway just to clean them and they did have quite a bit of gritty junk in them so I cleaned them and threw some fresh grease on all the metal parts, put it all back together and still had a sloppy sound but upon closer inspection...I discovered that the sound was coming from the the spur/pinion gear area....so...I tried to change the gear mesh between the spur and pinion gears in every possible position from super tight to super loose mesh and it still makes a crappy noise (it was definitely more loud/sloppy sounding the looser the gear mesh)....so my next idea was "maybe if I switch to a different pitch gear set-up..." anybody have any ides? Or am I just too damn picky about my truck sounding nice and not like a piece of junk!? LOL! I have heard Honchos that are very quiet...almost silent and thats what I want mine to sound like! Anyway, thank you very much for reading my thread and any help will be much appreciated! |
05-04-2013, 06:17 PM | #2 |
Rock Crawler Join Date: Jan 2013 Location: Laguna Niguel
| Re: **SCX-10 Gear noise...PLEASE HELP!**
I bought mine used and it had a badly worn pinion gear- the sound was awful, especially in reverse. Got a steel pinion and things improved greatly!
05-04-2013, 08:40 PM | #3 |
Rock Crawler Join Date: Oct 2012 Location: Casper
The outputs on my trans had loose screws.
05-04-2013, 09:45 PM | #4 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Are you running 32pitch or 48 48 would be quieter of course....metal gears ?? If you've checked your mesh, chances are you are a bit too picky...just saying. I run with a guy that runs 48 pitch gears....he's so quiet....yes, it's nice but quite frankly doesn't bother me. I run 32 pitch for the contact area and putting power to the ground...noisy or not. It's a truck |
05-04-2013, 09:50 PM | #5 |
Are you running 32pitch or 48 48 would be quieter of course....metal gears ?? If you've checked your mesh, chances are you are a bit too picky...just saying. I run with a guy that runs 48 pitch gears....he's so quiet....yes, it's nice but quite frankly doesn't bother me. I run 32 pitch for the contact area and putting power to the ground...noisy or not. |
05-04-2013, 10:00 PM | #6 |
Rock Stacker Join Date: Mar 2012 Location: Smokin loud.. Drivin pimp shit
like postclanker asked.. both spur and pinion metal? if so.. well hope tha sound dont bother ya too bad ...
05-04-2013, 10:27 PM | #7 |
Sorry for the double post ....couldn't delete one....
05-05-2013, 07:42 AM | #8 | |
| Re: **SCX-10 Gear noise...PLEASE HELP!** Quote:
05-05-2013, 07:43 AM | #9 |
| Re: **SCX-10 Gear noise...PLEASE HELP!** |
05-05-2013, 08:01 AM | #10 |
48 pitch huh.... Well, there's going to be some noise no matter what you run...do you have grease in the tranny??? Have you inspected those gears ? Try changing the spur and pinion....just put new ones in |
11-16-2014, 09:56 AM | #11 |
Newbie Join Date: Nov 2014 Location: South Africa
I actually have a similar problem, i bought mine new and assembled it as per booklet, at first I had to little grease in the diffs (after first run it became quite noisy so I redid them with lots of grease. Without the motor connected the chassis is dead quiet, as soon as i connect the motor it gets noisy and it doesn't matter how far or close the motor is to the spur gear.....I'm assuming its just motor noise
11-16-2014, 10:26 PM | #12 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
Look at a couple of things. First off is it the stock motor mount plate? Stock Transmission case? I run steel 32 pitch pinion and Steel Spur. I have a Super Shafty Ultimate Motor Mount Plate and a Vanquish transmission box. Very Quite, nothing in the transmission flexes. |
**SCX-10 Gear noise...PLEASE HELP!** - Similar Threads | ||||
Gear noise | Hardline | Axial AX-10 Scorpion | 2 | 08-18-2012 06:58 PM |
7955 gear noise... a little different | mudn_1 | Electronics | 1 | 02-10-2012 10:20 PM |
Wraith Gear noise | cumminsdzl | Axial Wraith | 7 | 08-12-2011 09:15 PM |
Gear noise | elitecrawler | HPI Wheely King | 8 | 06-29-2010 11:26 AM |
gear noise? | 93'wrangler | Axial AX-10 Scorpion | 7 | 12-08-2008 11:36 AM |
