05-05-2013, 02:06 PM | #1 |
Pebble Pounder Join Date: Jun 2012 Location: Lucerne Valley
| Dirty Axles
Taking the front axle apart to do Beef Tubes and the AX- 10 mod and I couldn't be leave how much dirt and junk was inside. I live in the desert so I know that it gets everywhere, is there something that can be done to help keep the inside a little cleaner? Thanks J |
05-05-2013, 02:12 PM | #2 |
Quarry Creeper Join Date: Oct 2011 Location: U.S.A
| Re: Dirty Axles
Pack your axles with lithium bearing grease.... it will keep your gears and axles clean and waterproof for a long,long time! |
05-05-2013, 02:17 PM | #3 |
Pebble Pounder Join Date: Nov 2010 Location: Below the snow line
The holes on the top side of the housing should be filled if not using them for a mount. Agreed that filled with a high quality grease will also help.
05-05-2013, 02:27 PM | #4 |
M3 screws or set screws to fill the holes help keep debris out. Also as was mentioned, pack the axles or at least coat the seams of the axles with some type of grease to catch the grit.
05-05-2013, 04:33 PM | #5 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| Re: Dirty Axles
i have had good luck with marine grease.. works great so far
05-05-2013, 08:32 PM | #6 |
Pebble Pounder Join Date: May 2012 Location: Sherwood Park
After ruining all my bearings, I sprayed the bearings and axle with a waterproof corrosion inhibitor. Then I used gasket maker to seal the housing, and the lockouts to the housing. Also plugged the one servo plate mount with a screw. Watertight now.
05-06-2013, 10:26 PM | #7 |
| Re: Dirty Axles
Thanks guys got the axle all cleaned up and put a good coat of grease around the edges to seal it up.
05-06-2013, 11:25 PM | #8 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
| Re: Dirty Axles Have you had the axles apart since doing this, I was wondering how easy they come apart with the gasket maker.
05-07-2013, 07:25 AM | #9 |
| Depends on the gasket maker. I used stuff that is made for serviceable parts, and should peel away pretty easy. I wouldn't use the stuff that is like glue.
Dirty Axles - Similar Threads | ||||
i got it dirty | malyon | 1.9 Scale Rigs | 1 | 04-01-2010 01:54 PM |
Dirty Thieves!!!!!!!!!!!!!! | Bobtail74 | Chit Chat | 30 | 07-24-2007 06:40 PM |
