05-08-2013, 05:51 PM | #1 |
Quarry Creeper Join Date: Feb 2010 Location: melbourne
| eBay cms?????
So I was scanning eBay and came across a chassis mount servo setup for 25 bucks and I was wondering if anyone had and feed back for it. Thanks.
05-08-2013, 06:29 PM | #2 |
Pebble Pounder Join Date: Mar 2013 Location: Honolulu
| Re: eBay cms?????
I'd also like to know! I seen it on ebay but I don't understand how it attaches to the chassis. Can anyone who is running this CMS also post some pics of it!
05-08-2013, 08:40 PM | #3 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
| Re: eBay cms?????
if it is the 3racing one dont do it. bought it and it broke the drag link after 10 mins the drag link sorry guys ment level 3 was really tired that night
05-09-2013, 10:36 PM | #4 |
| Re: eBay cms?????
I don't think it's 3racing but sorry to hear about your bad luck. It looks to be all aluminum but I'm not sure if I have to leave it at the stock ride height or not.
05-10-2013, 06:16 AM | #5 |
Quarry Creeper Join Date: Aug 2010 Location: Brisbane Australia
| Re: eBay cms?????
Didn't think 3 racing made a cms but if it is all aluminum then it is probably the level 3 Rc stuff and have heard mixed reviews on this setup. In all honesty you are better done the DIY job using the stock axle servo plate bolted to the frame if you want a cms solution. If you search on here there is a thread on how to do it.
05-10-2013, 06:21 AM | #6 |
Quarry Creeper Join Date: Dec 2009 Location: jackson,tn
| Re: eBay cms?????
Probably the level 3 cms with panhard with it. I actually bought one from Rpp and never used. I went with the ole stock servo mount to the frame. Doesn't look like it would hold up good, doesn't actually mount to the frame, it slides on and the panhard bar holds it in place somehow or another.
05-10-2013, 07:27 AM | #7 |
Quarry Creeper Join Date: Feb 2013 Location: SW Iowa
| Re: eBay cms?????
I have the level 3 cms with panhard, and if you can get past the looks of the raw aluminum it does work. The cms pinches in between the frame rails in front of the shock mounts. For a cheap cms it works but there are better options out there. If you want pics of it mounted I can get some when I get home.
05-10-2013, 03:31 PM | #8 |
Newbie Join Date: May 2012 Location: Pocono's
| Re: eBay cms?????
Link to the part would be grand.
05-12-2013, 03:08 AM | #9 |
Newbie Join Date: Jan 2013 Location: Small town
| Re: eBay cms?????
I think the Tips and Tricks sticky shows how to do it with the stock CMS plate. I did that with mine and was happy with it since it was basically free, but wanted it mounted a little higher so I made my own plate out of 1/8" steel sheet I already had. Only change I made was the holes for the servo mount higher, wasn't sure how high I wanted to I put 2 holes for adjustment, 1/8" and 1/4" higher.
eBay cms????? - Similar Threads | ||||
cms?? | savagebeast | Axial Wraith | 3 | 05-31-2012 05:38 AM |
rc4wd cms vs hand brothers cms kit | bronc4now | Axial SCX-10 | 4 | 05-16-2012 07:14 PM |
Cms?? | stanmondz | Axial SCX-10 | 3 | 05-03-2012 09:31 AM |
CMS help anything other then look? | bsj03 | Axial Wraith | 46 | 01-18-2012 09:26 AM |
Cms help! | xtian | Axial SCX-10 | 2 | 09-26-2010 10:10 AM |
