Thread: Clamping or Locking Hexes for SCX10 ?
Old 05-10-2013, 12:25 AM   #1
Smile Clamping or Locking Hexes for SCX10 ?
Hello, I am looking for clamp type wheel hexes for the SCX10. I have found some clamping hexes online but cannot find anything specifically for the scx10. I do not know if hexes like these will fit? I have broken pins and the hexes I have on the pins are shakey, even when tightened down.
These are real cheap! But will they fit my application?
Half Price! Hot Racing Aluminum 12mm Clamp On Wheel Hex for Wheely King #WK1008** - The Crawlers Store LLC
Thank you for your help
z50king is offline   Reply With Quote
Old 05-10-2013, 09:40 AM   #2
Default Re: Clamping or Locking Hexes for SCX10 ?
I bought a couple sets of those you linked to... the centering "nub" will need to be filed down flush so it does not protrude (which only takes a few minutes with a file) in order to work with the Scx10 style wheels. I also had to open up the ID just a hair with a dremel and a small cone-shaped bit in order to get them to seat all the way down on the axle flanges. Once modded they work well.
For under $4 a set it was worth the effort IMO
BodiBuilt is offline   Reply With Quote
Old 05-10-2013, 09:50 AM   #3
Axial makes them, they came with my Rubicon kit. 12mm hex with set screw.
raceeng18 is offline   Reply With Quote
Old 05-10-2013, 11:08 AM   #4
Those are what I am using on the rear of my rig. I am running Vanquish wheels and hubs and did not need to modify them to work. Only using them on the rear because I am running super 300's on the front and they need a 5mm hole, so I got some different ones for the front. I like the clamping type better than the binding type, they cant deform the stub.
DRTMI is offline   Reply With Quote
Old 05-10-2013, 01:18 PM   #5
Natedog's Avatar
These are the best ones that I've used.
Clamping or Locking Hexes for SCX10 ? - Similar Threads
SCX10 narrow wheel hexes TNT1 1.5 Scale Rigs 0 10-09-2012 02:43 PM
