05-10-2013, 09:11 PM | #1 |
Quarry Creeper Join Date: Dec 2012 Location: Toxaway
| Dual Batteries???
I have had my JK about 6 months now and am just starting to mod. The question is would it hurt to wire in 2 5k mah batteries together to give longer run time and better weight distribution. Also what would be the best way to accomplish this. I am planning on just making a custom y-cable so everything can be unplugged individually. Currently they are both in the JK just not wired together. I have on in the back and one in the front. I'm a bit new to all this and will appreciate the input. Weight doesn't seem to be an issue even with wheel weights it weighs in about 7.5lbs Thanks |
05-10-2013, 09:46 PM | #2 |
| Re: Dual Batteries???
Why do you currently keep two batteries in the truck like that? What are you getting for run time now? Depending on the motor and your driving style, 5000mah could give upwards of 3-4 hours of run time. In my experience anyway. I'm O.K. with changing batteries after such a long time, instead of adding all that weight high up on the frame like that. |
05-10-2013, 09:49 PM | #3 |
Pebble Pounder Join Date: Feb 2011 Location: Knoxville
I run 2 2650mah 3s packs on my scaler to even out the weight. You can make a connector like you mentioned or depending on what type of plugs you have you may be able to buy one. eBay and amazon both have them for deans plugs
05-10-2013, 10:02 PM | #4 |
Pebble Pounder Join Date: Apr 2012 Location: Bellingham
Yeah, that does seem like a bit overkill. I run 3s 2200mah, and I get an hour and a half and beyond depending on what kind of trails I'm doing. I bring three packs with me on day outings and rarely had to use the 3rd. A buddy uses a 3000mah in his 10+ # rig and easily gets 2 hours. And I agree with the above about having all that weight up there. Good luck! And if you choose to go big anyway, let us know how she rolls. :thumbup:
05-10-2013, 10:03 PM | #5 | |
| Re: Dual Batteries??? Quote:
05-10-2013, 10:09 PM | #6 | |
I may have to rethink the way I want to do this and try more experiments with weight and location of battery. I will say this it will crawl up about anything at the moment with solid traction. What is the best place to mount the battery. I know I want it down to keep the COG down as low as possible. | |
05-10-2013, 10:43 PM | #7 |
Quarry Creeper Join Date: Jan 2007 Location: Shingle Springs
Make shelf brackets to put the packs on the rocker guards. That's what I'm going to do. I have 2500 packs that I'll use. For 5000 packs you may have to put them up on edge.
05-10-2013, 11:29 PM | #8 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
i run dual 5k mah on the rock rails, i just plug in one at a time so i know when it's time to turn back to the parking lot |
05-11-2013, 01:36 AM | #9 |
Quarry Creeper Join Date: Aug 2010 Location: Brisbane Australia
I run 2x 3s 2100 on the side rails ( I have proline undertray so they attach to that) running in parallel so I have 4200mah and that lasts for ages.
05-11-2013, 06:12 AM | #10 | |||
I like the sound of mounting to the rock rails. Can you guys post some pics of how you mounted them or what kind of bracket I would use? Also how does this impact the crawling ability? I know the weight would be down low and evenly displaced but does it cause it to tip sideways at all? | |||
Dual Batteries??? - Similar Threads | ||||
dual batteries? dual motors? | mud$lut | Newbie General | 4 | 11-07-2011 05:25 PM |
Dual 35s batteries | hlrider130 | Electronics | 5 | 10-26-2011 09:07 PM |
Dual batteries | camobob | Redcat Crawlers | 10 | 02-25-2010 09:24 PM |
dual batteries with dual MM's? | ClodMaxx | Electronics | 6 | 02-19-2008 10:29 PM |
Dual batteries | milje | General Crawlers | 4 | 10-16-2006 01:29 PM |
