05-11-2013, 03:06 PM | #1 |
Newbie Join Date: May 2013 Location: Sugar Land
| Which oils/greases for servicing?
While waiting on my AX10 to be delivered I went ahead and picked up a SCX10 to feed the scaler in me. Played around in some mud yesterday. Photo is before it got really dirty with two more 5000mAh NiMH packs through it. My question is...which different cleaners and grease/lube should i use on the diffs, bearings, servo, and trans/transfer case? I'd like to make sure nothing bad is in the brushed motor, but as it's functioning i don't know if there is anything i can really do. . I'm going to do a complete tear-down and servicing/waterproofing with gasket sealer/dielectric grease. |
05-11-2013, 03:12 PM | #2 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
I usually have a can of WD40 and spray down all the exposed bearings and metal parts. For grease I coat the bearings and gears with Lucas Red N tacky. Haven't had a problem playing in the water Sent from a rock |
05-11-2013, 04:57 PM | #3 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| Re: Which oils/greases for servicing?
had good luck with marine grease
05-11-2013, 06:11 PM | #4 |
Thanks. Found an unopened Lucas Red N Tacky. I also have some marine lower case lube, 80-90 i believe and valvoline wheel bearing grease from auto repairs, dielectric grease, and gobs of other junk. I didn't expect to be able to use things i already own or can get at AutoZone. Back to tinkering. |
Which oils/greases for servicing? - Similar Threads | ||||
New Kit, greases, shock oils, etc? | Beej | Axial Wraith | 2 | 11-28-2011 08:31 PM |
Shock Oils! | thzero | Axial AX-10 Scorpion | 5 | 02-10-2011 09:08 AM |
Greases | tecboy | Axial AX-10 Scorpion | 11 | 01-22-2010 02:00 AM |
Dremel servicing | ecoli | Tools, and Procedures | 2 | 08-16-2009 02:02 PM |
shock oils | al3x_34 | General Crawlers | 0 | 07-06-2007 01:18 PM |
