05-12-2013, 09:18 AM | #1 |
Pebble Pounder Join Date: Mar 2007 Location: cleveland
| wroncho/truggy link issues
i got this chassis off a member on here and starting the build with wraith axles..its a scx based chassis with the tube work added so i figured this is where i can get the help and advice..i wanted to use the wrath axles since i had them anyhow and figured it would work out as i had planned.. the axles had the links already added and the front mounted up great..i flipped the trans to get the outputs lined up better..now im having issues with the top links hitting the drive shaft..im thinking maybe go with a 3 link..i know this has been covered but advice and pics would be great.. its sitting at 13.5 in wb..i like it right there..the rear links are way short so im going to have to make some up..also..is there a mfg the has the bent rod ends..the ones on these links has a brass bushing that falls out..any how..here are some pics..the way she sits mocked up.. link issues Last edited by a69baldone; 05-13-2013 at 06:37 PM. |
05-12-2013, 09:27 AM | #2 |
Rock Stacker Join Date: Mar 2013 Location: La Serena - Chile
| Re: wronco/truggy link issues
Did you tried with the transmission in the reverse position?
05-12-2013, 09:37 AM | #3 |
yes..its been turned around so the outputs on the transmission and the axles line up..im using a scx trans skid plate..im thinking i might have to go with a wraith since its wider maybe.
05-12-2013, 09:44 AM | #4 |
RCC Addict Join Date: Nov 2004 Location: union
Here's benders so you have an idea If you turn the trans the other way it should clear. |
05-12-2013, 10:06 AM | #5 |
The drive shafts seen like they are at a major angle with out the transmission swapped. i seen his thread and was liking his 3 link setup with the trans swapped..is there any disadvantage with the 3 link setup?
05-12-2013, 10:21 AM | #6 |
Rock Crawler Join Date: Mar 2012 Location: bel air
I find the effect of torque twist in the suspension is more exaggerated with a 3 link than a 4. I usually see it with my foff rigs more than a slower setup, but I am running a 3 link on my scx10 for the clearance issue
05-12-2013, 10:26 AM | #7 |
RCC Addict Join Date: Mar 2009 Location: Chilton
| Re: wronco/truggy link issues |
05-12-2013, 10:42 AM | #8 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
05-12-2013, 10:54 AM | #9 |
Thats what i was thinking that i would have driveline issues binding and snapping and premature wear...im undecided how to go about this..PM sent beatjeep
05-12-2013, 10:59 AM | #10 |
P M sent back
05-12-2013, 11:45 AM | #11 |
looks like i will have to go with a pan hard in front and rear if i run a 3 link..
05-12-2013, 11:50 AM | #12 |
Rock Crawler Join Date: Jul 2011 Location: palm desert (southern cali)
| I got mine to work I just bent my links my self I'm 4 linked Sent from my Galaxy Nexus using Tapatalk 2 |
05-12-2013, 09:34 PM | #13 |
Quarry Creeper Join Date: Jun 2012 Location: pomona
Not finished yet but this is how I worked mine...I 'm putting the Axial shock mounts on to try to perfect the articulation. Works pretty good so far.
05-13-2013, 06:15 PM | #14 |
them are some bent links there if i do say so..if i didnt have the welded sliders on the chassis i would try that but the uppers would hit my sliders mounting them on outside of the frame rails..still a work in process..grr
wronco/truggy link issues - Similar Threads | ||||
Scx Truggy Driveline Headaches & Issues..! | Big Tex | Axial SCX-10 | 11 | 10-14-2012 12:05 PM |
Castle link issues | TXJeeper1 | Electronics | 11 | 09-20-2011 06:28 AM |
Issues with my 4-Link | shierkahn | General Crawlers | 9 | 11-26-2007 11:35 AM |
Castle Link issues | badyj | Electronics | 1 | 05-15-2007 07:59 PM |
carbon link issues??? | emaxxjeremy | General Crawlers | 4 | 07-31-2005 05:05 PM |
