05-20-2013, 12:20 PM | #1 |
Newbie Join Date: May 2013 Location: I Don't Know
| A few questions..
Hi everyone, I am looking into buying a SCX (Either Honcho or Dingo). I do not know which one I should get. I would like a kit but I do not like the Dingo body/short wheelbase. So I guess ill get a Honcho and remove the electronics... Will this setup work? Motor and ESC: TowerHobbies.com | Castle Creations 1/10 SV3 Sidewinder WP 4600kV System Servo: Savox Servos, Savox SC-1256TG Standard Digital High Torque Titanium Gear Servo - A Main Hobbies - A Main Hobbies TX: Spektrum DX4S DSMR 4-Channel Surface Radio w/Telemetry [SPM4000] | Radios & Accessories - A Main Hobbies And all powered by: Traxxas 3S "Power Cell" 25C Li-Poly Battery w/Traxxas Connector (11.1V/3300mAh) [TRA2846] | RC Cars & Trucks - A Main Hobbies I really wish the SCX Honcho kit was still around.. Thanks in advance. Pgz |
05-20-2013, 12:25 PM | #2 |
Quarry Creeper Join Date: Feb 2013 Location: SW Iowa
| Re: A few questions..
Why not get a Jeep scx10 kit? Then you would get a better looking body and a kit to put together.
05-20-2013, 12:27 PM | #3 |
Most of that list will work but that's a lot of motor for a scaler. Most people run brushed motors, around 27t - 35t on 3s. The Holmes Hobbies BR-XL is a great esc for brushed motors. If you want to go brushless, you should get a sensored motor, it's the only way to get low end control from BL. You will need to waterproof it though, use a spray like Conformal Coating. Also, IMHO, if your going to spend the money on a nice radio, check out the Futaba 4PL. I've had better luck with Futaba then Spektrum... or, look into the hacked Flysky radio from Overkill RC. |
05-20-2013, 12:27 PM | #4 |
Pebble Pounder Join Date: Feb 2011 Location: Knoxville
I think the dingo kit comes with the links needed for the honcho wheelbase. I would probably just sell the dingo body and buy whatever body I wanted.
05-20-2013, 12:31 PM | #5 |
Rock Crawler Join Date: Oct 2012 Location: Garden Grove
Seems like a good setup. I'd go with 30c or better for the battery just based on all the suggestions/reviews I've read. I like my Futaba 4PL and have only used a DX3E, or whatever came with the TwinHammer and changed to my 4PL shortly afterward. I am planning a similar build later this year and wish there was a Honcho KIT, but I'll end buying the Honcho body kit from somewhere. |
05-20-2013, 01:08 PM | #6 |
@Jbailey: I will have to look at those. I did't know of such a things. Thanks! @johhny866: A 4600kv motor would be a lot of motor for this?! Lol I was looking for a 2200kv or lower! I am going to use this truck for hill climbing and mild crawling. I wanted Spektrum because all my other trucks run it. Then I can use the one TX for all of them. @brawlercrawler: I also did not know that the Dingo came with the longer links. Thank you @offroadance: I went with the traxxas 3s lipo because I use them in all my other trucks and they work fine. In fact castle recomends them! Thanks! Pgz |
05-20-2013, 01:38 PM | #7 |
Rock Stacker Join Date: May 2010 Location: Bluefield,WV
I just put together my first kit, SCX-10 jeep and went with a MMP esc and a Tekin 17.5 Redline motor. With the little running I have been able to do with it, it seems to be great. If you want to go brushless and still have the nice low end craw-ability I would go with a sensored motor esc combination.
05-20-2013, 01:55 PM | #8 |
I want brushless because that seems like the direction all the motors are going. Sensor motors are not waterproof right? I also hear that a damaged sensor wire can cause serious damage... How fast will a 35 turn Tekin go on 3s with the sidewinder? I want about 10 miles per hour or at least enough to kick up some roost. I don't really want to make it into a crawler but more or less a fun basher type rig. I basically want something like this... Axial Racing - Bender’s Custom SCX10 Prerunner Build Pgz |
05-20-2013, 01:57 PM | #9 | ||
| Re: A few questions.. Quote:
05-20-2013, 02:02 PM | #10 | |
I used to run brushed (HH 14t Puller on 6s) but switched to a brushless Tekin Pro4 3300 and love it! | |
05-20-2013, 02:10 PM | #11 |
| Re: A few questions.. a few coats of this on the electronics board will waterproof anything. Techspray 2106-12S HT High-Temp Silicone Conformal Coating |
05-20-2013, 03:14 PM | #12 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
4pl best all around for money...imo(most options for all rigs) Savox is great but Hitec is faster & smoother hands down 7955tg or bigger,the hobbico cs170 has 333oz torque$85!!! I run a 13t HH/Brxl & 35t tekin pro/FXR both on both scx10's great combos!!! Brushless pro 4, 13.5,4 pole,etc shreds stock drivetrain so need to upgrade asap!!! I have or at least tried all above & on these rigs most use brushed...I think??? The only major issue is brushless cost double & requires more upgrades for dependabiliy! 3s lipo...anything but Traxxas imo!!!(hobbypartz.com) Last edited by sic1to; 05-20-2013 at 03:34 PM. |
05-20-2013, 05:00 PM | #13 | |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
05-20-2013, 06:59 PM | #14 |
Rock Stacker Join Date: Mar 2013 Location: Temecula
i reccomend the 4pl! and traxxas lipos are alittle pricey. I have had very good luck with the lipos from hobbypartz.com. Cant go wrong with those for the price.
05-20-2013, 11:05 PM | #15 | |
Rock Crawler Join Date: Jan 2013 Location: Cen Cal
05-21-2013, 12:19 PM | #16 |
Ok So after more research I am going with a 35t Tekin Pro. So ill order, Honcho RTR 35t Tekin Pro Spektrum DX4S----It will connect to my other trucks. Steering Link Upgrade Set Maybe a Hitec Servo too... I will be running a 3s Traxxas lipo that I already have. Pgz |
A few questions.. - Similar Threads | ||||
lipo questions with charger questions can you all help | champ198 | Electronics | 16 | 05-02-2013 01:24 PM |
lipo questions with charger questions can you all help | champ198 | Electronics | 0 | 04-30-2013 05:54 PM |
Questions questions questions quest qowirnl | RYY | Newbie General | 11 | 10-04-2006 08:18 PM |
Questions? | krazymtbr | General Crawlers | 2 | 01-24-2006 05:06 AM |
