05-21-2013, 02:35 PM | #1 |
Newbie Join Date: Jan 2013 Location: Discovery bay
| link lengths ......curious
so ive been messing around with links and making my own etc. my question is for the front. What lengths are you guys running top and bottom? for a 4 link setup! im curious because i seem to have a little trouble on drive line angle. When i make the top ones a bit longer then the angle gets better but the the knuckles rotate further forward and the steering is a bit wierd. Any input would be great and what lengths you are running so i can duplicate. Thanks in advance
05-21-2013, 03:10 PM | #2 |
Pebble Pounder Join Date: Mar 2010 Location: chico
| Re: link lengths ......curious
I just picked up the vanquish titanium set-up for the scx10 currie axles, I'm still using the stock axles that came with he axial jeep kit. The links did the same thing t o my rig, clocked the axles forward. They also extended the wheel base about a 1/4 in or so. It's not a lot of info but its a direction. Good luck. |
05-21-2013, 07:30 PM | #3 |
Rock Crawler Join Date: Jan 2013 Location: Laguna Niguel
Usually the clockable c hubs help with this issue. You improve the driveline angle which rotates your steering forwards and then the clockable c hubs rotates just the steering back. I wish you could clock the more than the 8 degrees. I'm sure there is a mod for that. Since running wraith axles on my honcho I just drill new holes for the c hub screws and rotate to the desired degree. |
05-21-2013, 11:40 PM | #4 |
Quarry Creeper Join Date: Mar 2013 Location: Moscow Russia
| Re: link lengths ......curious here you go Front lower link 130 mm Front upper link 122 mm Rear lower link 138 mm Rear upper link 130 mm |
05-22-2013, 06:50 AM | #5 | |
Pebble Pounder Join Date: Aug 2011 Location: Aiken
never mind should have checked link for answer Quote:
Last edited by mnickolson; 05-22-2013 at 06:52 AM. Reason: should have checked link | |
05-22-2013, 08:16 AM | #6 |
very cool thank you for the lengths. I made new ones last night for the front but did same length top and bottom. being that the mounting point isnt the same top and bottom it looks to be a great drive angle. I will hopefully try it with the steering and all tonight
05-22-2013, 09:01 AM | #7 | |
Rock Crawler Join Date: Jan 2013 Location: Cen Cal
| Re: link lengths ......curious Quote:
05-22-2013, 09:49 AM | #8 |
makes total sense. I have a few to try considering im making them all. Thanks
05-22-2013, 10:39 AM | #9 |
I noticed some steering problems with my 4 mm difference in links length (8 mm is default). Wheels turning down. Axial C Hubs (AX30495) fixed that.
link lengths ......curious - Similar Threads | ||||
Link lengths | blckgnx | Axial SCX-10 | 2 | 03-26-2011 05:29 PM |
4-link and link lengths questions | T DAWGv12 | Axial SCX-10 | 5 | 11-27-2010 11:17 AM |
upper link lengths for SCX10 with stock four link | oscodawave | Axial SCX-10 | 4 | 11-19-2010 08:23 PM |
Looking for link lengths for 4 link on the Honcho | Skeeno | Axial SCX-10 | 5 | 12-20-2009 08:34 PM |
60/40 link lengths? | solomon7 | HPI Wheely King | 1 | 08-19-2007 12:45 AM |
