05-29-2013, 03:47 PM | #1 |
Rock Stacker Join Date: Mar 2013 Location: Salt Lake City
| Adding A BEC
Just a quick question hopefully. If I'm looking to add a BEC to my otherwise stock SCX10, is adding it to my system the only thing I need to do, or will I need a different ESC as well? I'm afraid the stock ESC may have issues. Thanks! |
05-29-2013, 03:49 PM | #2 |
Rock Crawler Join Date: Mar 2006 Location: Up North
You don't need a new esc for a bec unless yout current one is already on its last leg!
05-29-2013, 03:57 PM | #3 |
| Re: Adding A BEC
I'm currently having some steering issues (in another thread in this sub forum) that may or may not be stock ESC related. I'm throwing a BEC in there because I'm upgrading my servo to something a little beefier than stock and figured it was wise.
05-29-2013, 04:02 PM | #4 |
An external BEC is always a good upgrade and it doesn't break the bank.....especially when going to a stronger servo.
05-29-2013, 11:52 PM | #5 |
Rock Stacker Join Date: Mar 2012 Location: SoCal
| Re: Adding A BEC
...was thinking about doing the same thing. Just switched to 3s and need to wire in a BEC, currently causing repeated glitching in my otherwise perfect FXR. I wanted to pick up a CC BEC but thought that the Castle Link only works on PC? I wanted the option to program the voltage output but not sure if it'll work on my mac. Are there pre-programmed ones out there, or services where others will program for me? Or is it something I could borrow a friend's PC and be done with it? Castle Link would cost me more than the BEC itself, seems counter-intuitive.
05-30-2013, 07:45 AM | #6 |
Quarry Creeper Join Date: May 2010 Location: scotland
| Re: Adding A BEC the only thing you will need todo with your old esc is disconnect the red wire from the rx plug as you dont want two bec`s trying to work the same servo as you could end up killing your esc
05-30-2013, 10:37 AM | #7 | |
| Re: Adding A BEC Quote:
Yeah, I've seen this in tutorials. I'm sure I'll have a lot of questions when it comes time for the install. I just ordered the CC BEC today along with a new servo and a few fasteners (trying to build a general supply.) Do I need to utilize the castle link system? | |
05-30-2013, 12:22 PM | #8 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
| Re: Adding A BEC
yes you will need a castle link to program bec
05-30-2013, 02:21 PM | #9 |
| Re: Adding A BEC Castle Creations Castle Link Programming Kit This? Do I also need this? Castle Creations Link Quick Connect |
05-31-2013, 11:58 AM | #10 |
| Re: Adding A BEC
Bumping for info.
05-31-2013, 03:25 PM | #11 | |
05-31-2013, 03:27 PM | #12 |
| Re: Adding A BEC
I concur. I may just see if my LHS has one. I'm waiting for other components to come in for my build, so I'm not in a rush. Thanks! |
Adding A BEC - Similar Threads | ||||
adding lipo | huckdat | Venom Creeper | 19 | 02-26-2011 07:51 PM |
Adding a second rx to a tx? | 0lllllll0 | Electronics | 4 | 02-20-2011 04:50 PM |
Adding Cells | yotachump | Electronics | 4 | 02-01-2008 11:01 AM |
Adding cells | Jeepernick | Electronics | 8 | 08-17-2006 11:32 AM |
