05-29-2013, 08:12 PM | #1 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
| Transmission question
Are the gears in the scx10 and the Wraith transmissions the same? I have the one piece bottom gear in my trans now and want to use a bottom gear with out puts with the holes so I can use my E-maxx drive shafts. I don't want the aluminum bottom gear and Robinson has a bottom gear for the Wraith.
05-30-2013, 03:51 AM | #2 |
RCC Addict Join Date: Feb 2012 Location: UK
I think there are differences between the two....best bet....check the exploded diagrams for each and compare. :-)
05-30-2013, 07:41 AM | #3 |
Newbie Join Date: Jan 2013 Location: Downingtown
| Re: Transmission question
here is the manual for the wraith kit.... http://docs.axialracing.com/instruct...wraith-kit.pdf You can check part numbers from there against the SCX10 parts |
05-30-2013, 11:40 AM | #4 |
Thanks guys, they are the same part number in both manuals.
Transmission question - Similar Threads | ||||
Transmission question? | shwng1973 | Vaterra Twin Hammers | 7 | 02-20-2013 12:35 PM |
Transmission question.. | Beej | Axial Wraith | 3 | 12-06-2011 11:59 AM |
Transmission question... | phantom309 | Tamiya Txt-1 and Juggernaut | 7 | 08-29-2006 01:23 PM |
