05-29-2013, 10:17 PM | #1 |
Newbie Join Date: May 2013 Location: Delco
| Scx10 gearing question
If I put th 2.2 rims n tires on my scx10 do I have to gear it differently to make up for the bigger tires and also I want to lift and replace the stock suspension any advice what are some good shocks for a crawler
05-29-2013, 10:36 PM | #2 |
Rock Crawler Join Date: Jan 2013 Location: Laguna Niguel
| Re: Scx10 gearing question
If you want to rock race the gearing is fine, if you want to crawl you should gear down and or get a higher turn motor. IMO I stay away from lift kits and longer shocks it worsens performance because of higher cog. I'm running a wroncho right now with 2.2's stock 90mm length shocks, I just had to cut the body as needed. You can always raise the body for less of a weight penalty. Longer shocks also worsen driveline angles = broken or shortened driveshaft life. I just bought the Junfac piggyback shocks and couldn't be happier. Their large bore really gives you control as well as the piggyback. And no leaks and they look pimp and they don't cost that much. And.... You can see my rig if you search 7demo7 on YouTube |
05-29-2013, 10:39 PM | #3 |
If you haven't already, you should be widening your truck with the 2.2s. Any axle widener should help. I used the Junfac 17mm ones from RPP hobbies
05-29-2013, 11:34 PM | #4 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
No need to widen it. ESP if your running wraith axles. Gearing is a personal preference. What might be fast to me - could feel slow to you. Build your truck how you want with the stock gearing and take it out. If it runs hot- gear down. Need more speed - lower turn motor. Slowly tweeking and playing with it like this will also teach you the pros and cons to each setup. But ALWAYS watch your temps. No need to cook your gear. |
05-30-2013, 12:10 PM | #5 |
Yeah I just hav the stock scx10 axles for now but I want to get aluminum ones. Also I plan on lowering the motor and trans once I go higher...so you like thos junfac shocks ill have to check them out
Scx10 gearing question - Similar Threads | ||||
scx10 gearing question | rcwolf | Newbie General | 5 | 05-09-2013 06:21 PM |
Scx10 gearing? | o0wiz0o | Axial SCX-10 | 11 | 04-01-2013 07:35 PM |
Scx10 gearing and motor question | jayuk022002 | Axial SCX-10 | 1 | 12-28-2011 11:06 AM |
Scx10 gearing advice | jeepster73 | Newbie General | 2 | 03-06-2011 09:54 AM |
SCX10 Trail Honch Gearing | robdel24 | Axial SCX-10 | 1 | 01-11-2010 10:44 PM |
