06-08-2013, 07:10 AM | #1 |
Rock Stacker Join Date: Jun 2010 Location: Colorado Springs
| Wrangler Driveline Preferred
Just curious what preference of driveline you like to run? I am looking to upgrade. Thanks.
06-08-2013, 07:14 AM | #2 |
In the band for now. Join Date: Sep 2012 Location: roselle
| Re: Wrangler Driveline Preferred |
06-08-2013, 07:32 AM | #3 |
What is MIP? Sorry not sure what that is / means.
06-08-2013, 07:47 AM | #4 |
Rock Crawler Join Date: Jan 2013 Location: Laguna Niguel
MIP is the brand of driveshaft. Mine have never failed.
06-08-2013, 08:29 AM | #5 |
Do they fit the Wrangler? Any modifications? Thanks for the input by the way!
06-08-2013, 08:31 AM | #6 |
Just saw on MIP website that they do not fit the Wrangler... hmmmm
06-08-2013, 09:08 AM | #7 |
Quarry Creeper Join Date: Jul 2009 Location: Dublin,Ireland-Cluj,Romania
06-08-2013, 12:05 PM | #8 |
Rock Stacker Join Date: Mar 2013 Location: La Serena - Chile
maybe it says that don't fit because they rub on the spur cover but maybe you can if you trim it a little.
06-08-2013, 12:10 PM | #9 |
Newbie Join Date: May 2013 Location: Rocklin
I sanded my spur cover slightly using a dremel. I use MIPs and the Junfacs.
06-08-2013, 12:29 PM | #10 |
Rock Crawler Join Date: Jul 2012 Location: Grand rapids
I have MIPS on my rubicon and I have all RRP gears and it rubs a tiny bit but after a good run it only touches when in a bind
06-08-2013, 12:35 PM | #11 |
RCC Addict Join Date: Feb 2012 Location: Ca.
MIP10145 This is an MIP Splined Center CVD Driveshaft Kit for the Axial SCX10 trail trucks and crawlers (does not fit Jeep Rubicon models). The MIP Spline Center CVD Kit for Axial SCX10 vehicles (does not fit Jeep Rubicon models), replaces the stock plastic drive shafts with a high quality drive shaft kit that requires no vehicle modification to install. Unless you remove or modify trans cover. Last edited by raceeng18; 06-08-2013 at 12:37 PM. |
06-08-2013, 12:39 PM | #12 |
trim de spur cover or remove it,very simple
Wrangler Driveline Preferred - Similar Threads | ||||
Preferred shock oil | jeremyfowler33 | South Carolina | 11 | 02-23-2012 05:09 PM |
Preferred Paddle Tires ? | RcRun | Formula Offroad | 0 | 05-03-2011 11:36 PM |
preferred brand paint | ThinkTank | Paint and Body | 9 | 11-05-2006 07:05 PM |
