06-08-2013, 11:55 PM | #1 |
Newbie Join Date: Feb 2009 Location: Goodwood
| How do I Honcho a Dingo?
Found this out after I got the truck, that the Dingo is shorter then the Honcho. How can I get the wheel base of a Honcho or even make it 13"? Thanks guys Cheers |
06-09-2013, 12:02 AM | #2 |
Rock Crawler Join Date: Aug 2012 Location: 909 area
| Re: How do I Honcho a Dingo?
get honcho links or make your own
06-09-2013, 04:35 AM | #3 |
Quarry Creeper Join Date: Sep 2011 Location: Lexington
You'll need longer drive shafts also. And obviously the Dingo body will no longer fit. Other than that though I think it's a fairly simple "conversion".
06-09-2013, 07:29 AM | #4 |
Quarry Creeper Join Date: Dec 2010 Location: Alberta
You don't need longer drive shafts because they use the same drive shafts!!!
06-09-2013, 07:34 AM | #5 |
Rock Crawler Join Date: Mar 2013 Location: columbus
| Re: How do I Honcho a Dingo? The parts list you will need to do a honcho. I did not give part numbers for the honcho bumpers or drive shafts. This is what you wiil need to do the rear suspension. I dont know if u have a kit or a rtr but if you have a dingo kit you will need to by the bolts nuts and lower 130mm link. hope this helps. If you whant to run the 13in wheelbase you can use the rear honcho links on the front and 4link the front axle. You will need to do the sterring mod to put the servo on the frame. link at bottom for servo mod Axial paet numbers needed AX80043 AX80054 AX80018 AXA434 AXA121 AXA1052 How-to relocated your Servo on the C-frame: Last edited by greengoblin; 06-09-2013 at 07:37 AM. |
06-09-2013, 08:38 AM | #6 |
| Really??? Why does the kit come with a long and a short version? And the mip's are offered in either honcho version or dingo version? Makes sense to me that if you have a longer wheelbase you'd need longer drive shafts......
06-09-2013, 10:34 AM | #7 |
| Re: How do I Honcho a Dingo? Duxx Axial sets ther truck up with the long shaft in the dingo.Take the shaft halfs the more spline engagement you have it will make it harder to twist the shaft. One shaft is reinforcing the other shaf. But more dead space you have the easier it is to do this. This is the shaft frome the front of my dingo and was only run for about 1 day. I put it into my boys creepr cuz his was worn out and dropped a pin. |
06-09-2013, 07:42 PM | #8 |
Quarry Creeper Join Date: Mar 2009 Location: Grande Prairie, AB, Canada
You can run the shorter ones in the dingo, however the long ones work also. I personally run the longer ones in my dingo. Sent from my GT-I9100M using Tapatalk 4 Beta |
06-09-2013, 07:46 PM | #9 | |
This might help you out. Cheap Stock drive shaft upgrade I have done this to both my rig and my sons and No longer have that issue. Sent from my GT-I9100M using Tapatalk 4 Beta | |
06-09-2013, 10:16 PM | #10 |
| Re: How do I Honcho a Dingo? Just saved that to my favorites. That is good info to know I can say I dont think I would have ever thought of that. Well back to topic. |
How do I Honcho a Dingo? - Similar Threads | ||||
Honcho or Dingo | PaF | Axial SCX-10 | 6 | 07-20-2012 03:27 PM |
Dingo or another Honcho???? | AsILayDying | Axial SCX-10 | 21 | 08-26-2011 01:49 PM |
honcho vs dingo | LUNAticCrawlingCrew | Axial SCX-10 | 11 | 07-26-2011 04:13 PM |
Honcho or Dingo?? | geekfreek95 | Axial SCX-10 | 11 | 02-23-2011 10:07 PM |
honcho vs. dingo | geekfreek95 | Axial SCX-10 | 2 | 02-16-2011 05:27 PM |
