06-13-2013, 08:17 AM | #1 |
Pebble Pounder Join Date: May 2007 Location: Titletown
| Drive Shafts for SCX10?
Okay what fits? MIP says they do not have a set to fit the JK Rubicon. Anyone know what is the best front and rear shafts that fit the Rubicon SCX10 like to get it ordered today. Thanks Dave |
06-13-2013, 09:21 AM | #2 |
Quarry Creeper Join Date: May 2012 Location: Houston
| Re: Drive Shafts for SCX10?
I have the junfac shafts for the wraith and the fit perfect.
06-13-2013, 09:31 AM | #3 |
Quarry Creeper Join Date: Jul 2009 Location: Dublin,Ireland-Cluj,Romania
mip will fit JK but with some trimming or removing the gear cover
06-14-2013, 01:31 AM | #4 |
Quarry Creeper Join Date: Jul 2011 Location: Seattle
Are you talking about the transmission to axle shafts? If so, you just run the updated through hole trans outputs, and through hole diff inputs (If you have an alder SCX10) with t-maxx driveshafts, and you will never break anything. And it is cheap to do. Or if you are trying to fit in and just run bling aftermarket BS to impress people, there are several "Shiny" expensive, not as good options available.
06-14-2013, 06:09 AM | #5 | |
06-14-2013, 08:42 AM | #6 |
Newbie Join Date: Jul 2012 Location: The I.E.
You can give the Twin Hammers shafts a try I know on the SCX-10 they are about 2mm from the bearing which can be easily filled by washers. But in your case they may just fit right. |
06-15-2013, 07:02 AM | #7 |
No, Im looking for a good metal bullet proof shaft, not bling but the build is on the heavy side with a lot of stuff. WIth thr Torque I will have and all the gears updated I want to make sure the drive shafts are not a weak point anywhere. T bought s set of MIP's already just waiting on them, My alxe's themselves are the only weak link, but that upgrade will come later or the plastic Axial housings may hold up well. |
06-15-2013, 11:56 AM | #8 | ||
| Re: Drive Shafts for SCX10? Quote:
Maxx shafts are a good driveshaft option as well but require more clearancing, are not much cheaper than mips and are even less scale "looking" than mips. | ||
06-21-2013, 11:18 AM | #9 |
Rock Stacker Join Date: Feb 2013 Location: Ottawa
According to MIP the rubicon should be using the wraith shafts. I just ordered mine and will post how it works.
06-21-2013, 11:54 AM | #10 |
The shafts work, just like Kitty said. But you have to trim you motor cover or remove it and run it with the spur gear open. I elected to trim mine as you can see in the pic the MIP shafts with the spur cover on. |
06-21-2013, 03:04 PM | #11 |
Rock Stacker Join Date: Jan 2013 Location: Brownstown
ok, so the SCX10 drive shafts that say that they work on all models except the Rubicon kits. I have mirrored my trans, so I have no gear cover. Would I need to buy specific through pins, or would the through pins from my wild bore shafts work. I just don't know what thread the MIPs use. Also, do the universals come with holes through both sides, or do those need to be updated to take a through pin.
06-21-2013, 03:59 PM | #12 | |
Quarry Creeper Join Date: Jun 2013 Location: Escondido, San Diego, CA
I mirrored the transmission yesterday and the MIPs still fit no problem. With the mirror you don't have a gear cover so no big deal. | |
06-21-2013, 10:28 PM | #13 | |
The mips use an m4 set screw, traxxas screw pins will also work. | |
06-22-2013, 12:21 AM | #14 |
Newbie Join Date: Mar 2013 Location: Vancouver
So, are you guys running the Wraith Part no. on your SCX10?
06-22-2013, 12:31 AM | #15 |
Not specifically the wraith version... but I've mixed and matched hubs from the scx/ax, summit and wraith versions as needed. The m3 screw pin of the wraith hubs are my least favorite to deal with. The male and female bones are identical.
06-23-2013, 06:39 PM | #16 |
Newbie Join Date: Oct 2012 Location: indonesia
I just change after one year playing with motors 27T and 45T (stock shaft) with no problem at all, I replace with " top cad" steel shaft as replace for the crawling fun with 55T motor
08-19-2016, 08:21 AM | #17 |
Newbie Join Date: Jul 2016 Location: Staten Island
I bought the Junfac and the MIP and with 109mm shocks the junfac were too short and the MIP binds because of the angles. Back to stock shafts searching for long enough shafts, possibly Ujoint style that can handle the angle without binding at the joint. Any suggestions?
08-19-2016, 05:22 PM | #18 |
Quarry Creeper Join Date: Sep 2010 Location: Gilbert, Az
I am looking to replace my broken shaft(s) too. i was looking at these from RPPHOBBY: AXIAL Poison Spyder Wraith Front & Rear driveline ($23.00) WILL THESE WORK ON MY STOCK SCX10 AXLES & TRANS? THANKS!!! |
Drive Shafts for SCX10? - Similar Threads | ||||
drive shafts for modified scx10 | creaturecrawler | Axial SCX-10 | 8 | 09-17-2012 03:07 PM |
scx10 drive shafts | demonut | Axial SCX-10 | 4 | 05-23-2012 05:46 PM |
scx10 drive shafts | mikeman84 | 1.9 Scale Rigs | 5 | 10-28-2010 05:18 PM |
