06-16-2013, 08:42 AM | #1 |
Quarry Creeper Join Date: Jun 2013 Location: Escondido, San Diego, CA
| Link mount spacers
So I have the Vanquish Currie rockjock axles I just installed along with the VP titanium link kit. The rod ends are a little smaller so they slide back and forth in the link mounts (both upper and lower mounts on axle side). What do people use for spacers, so should I not worry about the 2-4mm of sliding back and forth? Hope that all makes sense i'm new to all this so i might describe things the wrong way. Any help would be great, trying to finish my build this morning, just gotta solder electronics and mount tires |
06-16-2013, 08:51 AM | #2 |
| Re: Link mount spacers
try using some washers as spacers
06-16-2013, 09:20 AM | #3 |
I use some small metal/nylon washers (appropriate thickness) even on the stock (plastic) link mounts... minimizes plastic stress and mount disfiguration. That and don't over tighten the bolt/nut. using a nylock nut insures it's not coming loose. and only requires it be snug. |
Tags |
link, spacer, vanquish |
Link mount spacers - Similar Threads | ||||
VP XR10 Upper Link Mount Spacers (Limited availability ) | moes670 | Chassis and Suspension | 13 | 11-12-2012 06:24 AM |
Y-Town BJ4 Link and Shock Spacers and Setup | cpercival | Axial XR10 | 9 | 03-06-2012 09:40 AM |
4 link spacers | coryjones | Superclass Crawlers | 3 | 02-19-2011 09:05 PM |
BWD Modular Servo Mount/Battery Tray/Adjustable Upper Link Mount | billet works | HPI Wheely King | 18 | 07-05-2010 10:52 AM |
