06-17-2013, 08:11 PM | #1 |
Newbie Join Date: May 2013 Location: Stuck in Folsom prison!
| project box?
Ok so i have been lurking on this forum for years not really a newbie to rc crawling or 1:1. So i finally need some advice. I'm going to be moving my electronics and i have decided to use a RS project box. I'm liking where you guys are placing them i'm just curious about how you guys are mounting them and what to? if anyone could put a link or a picture showing how they mounted it it would be much appreciated. also i was wondering what is your guys prefereed method of waterproofing the box? here is some pics of my recently sold 1:1 |
06-17-2013, 08:18 PM | #2 |
Quarry Creeper Join Date: Jan 2013 Location: Spokane
| Re: project box?
I screwed mine through the rear crossmember.
06-17-2013, 08:20 PM | #3 |
| Re: project box?
i was going to run it on the front i'm still using the stock honcho body with the bed cage. did you silicone or waterproof the holes you screwed through? Thanks |
06-17-2013, 11:59 PM | #4 |
Rock Crawler Join Date: Jan 2013 Location: Laguna Niguel
| Re: project box?
I think most drill holes in the bottom to allow water to escape. All the while your electronics are waterproofed inside. Guys correct me if I'm wrong...
06-18-2013, 07:05 AM | #5 |
Quarry Creeper Join Date: Jul 2009 Location: Dublin,Ireland-Cluj,Romania
| Re: project box?
double sided tape on the rails with some aluminum plate,that should do the job
06-18-2013, 12:07 PM | #6 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
| Re: project box?
i used servo tape to anchor mine down - holds very well. i seal them up with some liquid electrical tape around the seam since it's WAY easier to get back into vs silicone or shoegoo and still seals it up. you can mount them to pretty much anything with a solid base. best solution for mounting would be to anchor onto some "boat side" sliders or to plates mounted on top of slider outriggers. remember to pick up some servo extension wires so you can leave pigtails hanging out of your project boxes for quick disconnection w/o having to open it up. here's mine. exterior's changed a bit since taken, but the electronics placement is pretty much the same. notice the velcro on the sides of the boxes - holds down my Honcho body along with the 2 hood pins - the servo tape is that strong and i haven't replaced it yet! Last edited by Perkolator; 06-18-2013 at 12:11 PM. |
06-18-2013, 09:05 PM | #7 |
| Re: project box?
sweet thanks for the ideas guys and perkolator for the pic much appreciated.
project box? - Similar Threads | ||||
Project box size | Soundlzrd | Axial SCX-10 | 6 | 02-21-2013 04:57 PM |
Tekin in project box?? | CHOPPERMECH11 | Electronics | 4 | 11-19-2012 02:10 AM |
ESC in a project box question. | DaveinSac | Axial SCX-10 | 3 | 10-05-2011 10:33 PM |
Project box for front axel | Arct1k | Tamiya Clod Buster | 1 | 12-23-2008 10:06 AM |
