06-18-2013, 02:37 PM | #1 |
Newbie Join Date: Nov 2012 Location: Sarnia
| Tekin pro4 and mmp settings?
maybe someone can help. i just picked up a tekin pro4 3300kv. going to run it on a mamba max pro. i have a castle link. just wondering on what settings i should be looking at setting up. first time running brushless. little more info. i have a scx10 with wraith axles. running 2.2 tires. 3s battery. rrp trans gears. changed to 32 pitch. 12/58. mip drive shafts. upgraded diff lockers. so the truck should be able to handle the motor. just not 100% sure on settings. going from the stock ae-2 to this setup. thanks. |
06-18-2013, 02:42 PM | #2 |
Sensored only and no cheat is a good starting point. The rest is dependent on rig pretty much. Also double check the c rating of your packs, that pro4 pulls some amps. |
06-18-2013, 03:05 PM | #3 |
Quarry Creeper Join Date: Jun 2013 Location: Escondido, San Diego, CA
| Re: Tekin pro4 and mmp settings?
I have a MMP and Tekin pro4 HD in my SCTE 2.0 racing truck.. I had to get 65C-130C burst batteries to handle the amp draw and with a 6000 mah 2s I only get ~10 minutes! but that is racing and full throttling/braking all the time. Also had to use an external BEC. As for settings, use sensored and no cheat, and put drag brake on (so if you let off the gas during climbing/crawling, you don't just roll back down). You could also play with your throttle curve but thats personal preference. |
06-18-2013, 07:33 PM | #4 |
cool thanks guys. the crawling speed of brushed and also wheel speed. just need to dail in the drag brake now. |
Tekin pro4 and mmp settings? - Similar Threads | ||||
Lipo discharge rate and MMP/Tekin Pro4 in Wraith | bbking9 | Electronics | 7 | 07-09-2012 06:49 PM |
MMP settings w/pro4 | Mike5025 | Axial Wraith | 17 | 06-20-2012 10:14 PM |
