06-18-2013, 04:12 PM | #1 |
Quarry Creeper Join Date: Jun 2013 Location: Escondido, San Diego, CA
| stock Axial maxxis trepador tires
Last week I finished building my SCX-10 Jeep kit with many upgrades, however Rock Beasts are still out of stock so I am still running the stock plastic wheels and Maxxis Trepador tires. My problem is that under full flex the opposite tire folds over the side wall wayyy to easy, causing rollovers. Are the stock foams just pieces of crap or what? |
06-18-2013, 04:41 PM | #2 |
Rock Crawler Join Date: Dec 2011 Location: thurmont
| Re: stock Axial maxxis trepador tires
i wouldnt say the stock foams are crap. but i'd invest in some better ones.
06-18-2013, 04:43 PM | #3 | |
Quarry Creeper Join Date: Feb 2006 Location: In da 801 "AKA Tiny"
| Re: stock Axial maxxis trepador tires Quote:
06-18-2013, 05:30 PM | #4 |
| Re: stock Axial maxxis trepador tires I actually just got my Lil Nova dual stage foams in the mail, and they are huge foams (compared to stock) with a hard compound on the inside so they should work way better. Waiting for Rock Beasts 1.9s to get back into stock before using them though.
06-18-2013, 05:39 PM | #5 |
RCC Addict Join Date: Apr 2011 Location: San Diego
Yea I would say the stock foams are junk. I mean they are ok for a light rig but if you side wall at all they will fold easily. Waiting for some funds to order more CI dual stage foams for my treps.
06-18-2013, 06:11 PM | #6 |
| Re: stock Axial maxxis trepador tires Agreed. If I had run the kit stock at all then maybe they would have worked. But i upgraded 75% of the stock kit, so its much heavier (especially with currie axles)
02-20-2014, 05:04 PM | #7 |
Pebble Pounder Join Date: Feb 2014 Location: Hampton Roads
My Rig is stock and the stock foam with the treps will fold over in a blink
02-20-2014, 05:20 PM | #8 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
Once you get the a Rock Beasts, DO NOT mount them up with the stock foams. When you buy the RBs, go to Crawler Innovations and buy a set of Duece Wild foams for them. They will perform soooo much better.
02-20-2014, 05:51 PM | #9 |
What would be a good Combo/foam setup to order for my stock Treps?
02-20-2014, 07:10 PM | #10 |
How heavy is your rig? Email Eddie at Crawler innovations and see what Lil Nova foam he recommends. |
02-20-2014, 07:12 PM | #11 |
Yea, I did end up emailing him after I had posted this Sent from my SGH-M919 using Tapatalk |
02-20-2014, 10:50 PM | #12 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Stock foams are junk...no matter what the weight of your rig. Spend the nickel and get some CI foams, made a world of difference for me.
02-23-2014, 03:54 PM | #13 |
Newbie Join Date: Dec 2012 Location: Canada
should also note, the stock wheels are "vented" If you put some good tape over the holes, and drill a new one, but smaller it will slow down the air flow out of the tire. Kind of give you "tire pressure" but allow for some air to escape when it gets more of the rig's weight on it.
02-23-2014, 03:57 PM | #14 |
Newbie Join Date: Dec 2013 Location: lansing
RPP has rock beasts in stock
02-23-2014, 05:28 PM | #15 |
Pebble Pounder Join Date: Oct 2005 Location: Noblesville , IN
| Re: stock Axial maxxis trepador tires |
02-23-2014, 08:42 PM | #16 |
Pebble Pounder Join Date: Jan 2014 Location: Staten Island
I was pretty much going to say the same thing as JeepExplorer. i covered up my holes with CA glue and plasti dip over that. I did it more cuz i would run in water and then have a 5lb wheel for weeks and it was a b!tch to get the water out (water destroys open cell foam), but it actually helps in not having the tire fold over as well, off camber situations are a lot more survivable. my $.02 I don't have any holes in my wheels.. |
stock Axial maxxis trepador tires - Similar Threads | ||||
Axial 1.9 Maxxis Trepador tires | chino63 | Tires and Wheels | 41 | 02-19-2015 04:54 PM |
Axial 1.9 Maxxis Trepador Tires - AX12019 | BENDER | Tires and Wheels | 29 | 10-10-2014 08:10 PM |
CC-01 on Maxxis Trepador Tires? | alexchen86 | 1.9 Scale Rigs | 6 | 02-26-2013 11:39 AM |
In Stock! Axial 1.9 Maxxis Trepador Tires R35 (2) | RPP Hobby | RPP Hobby | 6 | 12-15-2012 03:05 PM |
maxxis trepador tires? | yjdavid | Tires and Wheels | 25 | 10-04-2010 08:21 PM |
