06-20-2013, 10:14 PM | #1 |
Quarry Creeper Join Date: Jun 2013 Location: Escondido, San Diego, CA
| Mounting bulldog winch on rc4wd jk rampage bumper
Anyone have any tips for mounting the bulldog winch on the rc4wd jk rampage bumper? Theres four holes but seems like you can only bolt the 2 back ones. If you were able to mount it, which screws and nuts did you use? Thanks |
06-20-2013, 10:19 PM | #2 |
Rock Crawler Join Date: Aug 2012 Location: 909 area
| Re: Mounting bulldog winch on rc4wd jk rampage bumper
I mounted one left corner and one right front had to screw in at a angle but it straightend its self out lol
06-20-2013, 10:44 PM | #3 |
| Re: Mounting bulldog winch on rc4wd jk rampage bumper Did you use nuts on the rear only then? I guess I just gotta find screws with the same thread. The ones I bought are the wrong threading i just wanna install it! |
06-20-2013, 11:49 PM | #4 |
I didn't use nuts on any the screws I ussed were from a axial kit and it hold it in place firm it been rolled and everything
06-20-2013, 11:53 PM | #5 |
Pebble Pounder Join Date: Feb 2013 Location: Fresno
This bumper correct? The threads in the bumper are m3 but the plate for bulldog winch needs to be threaded to m3 because they are 2mm holes. A buttonhead m3 x 4 or 5mm will do just fine on all 4 corners. no need to put lock nuts on them if you got all four. I did have to take a 2mm allen wrench and file the short side down to get to all the screws in a decent manner. Not stripping them to be exact |
06-21-2013, 12:09 AM | #6 |
Yeah that same bumper. Thanks for the info on the screws I need, I bought m2.5 so hopefully my LHS has them dont wanna wait until next week =P Edit: p.s., the rubicon looks sweet, love the color. Are your front tires backwards or do you run the treads backwards? Those are the stock tires wheels and foams? Last edited by uclabruins89; 06-21-2013 at 12:10 AM. Reason: Whoops |
06-21-2013, 12:36 AM | #7 |
Yepp stock wheel-tire-foam with all this added weight up front the tires get a bit squashy now, good for crawling and climbing bad for turning radius. I do run a 10 ounce battery behind the front shock tower though Thanks the paint is tamiya ts-46. I have been experimenting with them turned around, so far with them turned on the front I notice better grab on the rocks. Last edited by BuhBoombuh; 06-21-2013 at 12:41 AM. |
06-21-2013, 03:23 AM | #8 |
| Re: Mounting bulldog winch on rc4wd jk rampage bumper Are you sure they are m3? I had bought m2.5 and they seemed too large, seems like the holes would be m2?? Or is mine just different?
06-21-2013, 04:00 AM | #9 |
| Re: Mounting bulldog winch on rc4wd jk rampage bumper Im dumb. They are M2.5, I had to screw through the black coating material which got into the hole. I thought I was rethreading it with how hard I had to screw it in but after clearing the stuff out it went in and out easily. Just so others know, M2.5 screws work
06-21-2013, 04:40 PM | #10 |
| Re: Mounting bulldog winch on rc4wd jk rampage bumper M3 screws went right in on mine, I ran a M3 threader through them and got the black paint out first though. Good to see your back on pace have fun with it. |
06-21-2013, 05:32 PM | #11 |
| Re: Mounting bulldog winch on rc4wd jk rampage bumper Back off pace =P i was screwing the M2.5 in and out to clear the black paint, and torqued off one of the screw heads . Now i gotta find a small screw extractor blahhhhh lol
Mounting bulldog winch on rc4wd jk rampage bumper - Similar Threads | ||||
Winch vs Rampage bumper | JandG | Electronics | 0 | 02-03-2013 07:15 PM |
