Thread: SCX10 Link length?
Old 06-24-2013, 01:58 AM   #1
Default SCX10 Link length?
Hi there,
I got a SCX10 Honcho chassis with no upper or lower links and will be making my own. Can anyone tell me the length of both the upper and lower/ front and rear lengths? From eye to eye or total length.
That would be awesome!
Stan3535 is offline   Reply With Quote
Old 06-24-2013, 07:12 AM   #2
Default Re: SCX10 Link length?
That all depends. What wheelbase are you looking for (Dingo, Honcho, etc.)?
maraudriii is offline   Reply With Quote
Old 06-24-2013, 10:46 AM   #3
Oops...I left that out. It is the Honcho. Thanks!
Old 06-24-2013, 12:30 PM   #4
I can probably help you out with that but I am at work until late tonight. I just did my own links. I believe my longest ones were 5 1/4" eye to eye. My shortest ones were 4 3/4" eye to eye but I still have to put everything back together and check lengths. I plan on trimming as needed.
JetBlast is offline   Reply With Quote
Old 06-24-2013, 12:59 PM   #5
If you make the top ones a little longer you get a nicer drive shaft angle.
o0wiz0o is offline   Reply With Quote
Old 06-24-2013, 01:45 PM   #6
Ya that would be awesome. No rush. Whenever you get around to reassembling them I would love to know the measurements. Thanks
Old 06-24-2013, 01:49 PM   #7
Thats funny you say this. I put on a suspension lift on my real truck and did this. It also gives you a little extra lift because it tilts your entire diff outwards. But then a mechanic told my that the drive shaft angle coming out of my transfer case is critical th match my drive shaft angle going into my Diff?
Old 06-24-2013, 05:30 PM   #8
That's funny because I actually used all 5 1/4 links on my rear on accident and took notice to that. My drive shaft was practically straight into the axle without any bends on the joint
I have some extra material so I may fabricate some longer upper links to match the lowers but I will see what everything looks like when put back together later this week. I am going to take my axles apart on Wed and put some lithium silicon grease inside them before reassembly.
Old 06-24-2013, 07:13 PM   #9
If I where you, I would get the body I was planning on running, and make the links match the wheelbase of that first... Also I know for real vehicles you want the Pinion of the diff pointing directly at the output it attaches to. This way when the suspension cycles it dosn't have a hard angle when the suspension is compressed, or unloaded.
JeepExplorer is offline   Reply With Quote
SCX10 Link length? - Similar Threads
4-Link upper link length? TNT1 Axial SCX-10 0 09-28-2012 03:07 AM
upper link length for honcho with 4-link truss 2500hdon37s Axial SCX-10 19 08-04-2012 08:46 PM
Link length Kingpin EnRoute Berg 0 08-28-2011 04:20 PM
3 Link 4 Link length question squad2man HPI Wheely King 4 03-05-2010 07:56 AM
Scx10 upper link length HOSS Axial SCX-10 1 01-29-2009 11:39 AM
