06-28-2013, 08:39 PM | #1 |
Newbie Join Date: Jun 2013 Location: Wayne
| My JK
I thought I would start kind of a build/tech thread for my JK. I've had this thing for awhile now but today was the first time I've really got to really use it. I am shocked at the abilities these little things have. I started making a little trail in a small patch of woods behind my house using a weed eater, a hatchet, and a machete. The problem I have is that to get to where I can crawl a little, there's a steep little hill I have to climb to get there. It's probably about a 20ft stretch but it gets progressively steeper the farther you go. I really need more weight in the front and a little more power. I started working on that after I called it a day but more on that later. The picture does not really do it justice but about 3/4 of the way up it's about a 60 degree incline. I never could make it to the top but hopefully after a few mods I can make it. This is about as far as I could get. |
06-28-2013, 08:47 PM | #2 |
After my battery started getting weak I took it back inside and decided I was going to relocate the battery to the front. Luckily I live about a 1/4 mile from a local rc store so I went and got the hardware I thought I needed. Turns out I was just a tad conservative with my measurements and both sets of screws were too short. By this time the shop was closed so that project is on hold for right now. I then decided to go ahead and take the rear tire carrier off to take some weight off the rear. That is where I am at right now. Next week I should be able to get the correct hardware so I can move the battery and then I will clean up the wiring and button it back up. |
06-28-2013, 08:50 PM | #3 |
So in case moving the battery is not enough, I might be on the lookout for some more power. Can this be achieved with maybe a new battery or am I looking at a different motor? I am running a 5500mah lipo right now. I know this is a "crawler", but in my situation I might need just a touch more wheel speed. Is there an easy way to accomplish this? |
06-28-2013, 08:55 PM | #4 |
Rock Stacker Join Date: Jun 2011 Location: st.louis
| Re: My JK
you cann change a lot in just changing the pinion .
06-28-2013, 08:59 PM | #5 |
RCC Addict Join Date: Oct 2012 Location: Norcal
| Re: My JK
Mine is set up pretty much as a crawler to but, I just put a RC4wd Ax2 two speed tranny in mine. Crawls slower than before and 2nd gear rips it up.
06-28-2013, 09:11 PM | #6 |
Quarry Creeper Join Date: May 2012 Location: Houston
| Re: My JK
Nice rig and crawl spot man. Good job on the super nintendo too!
06-28-2013, 09:25 PM | #7 |
06-28-2013, 09:28 PM | #8 |
| A two speed transmission sounds like a good option in my situation. Sounds like a fairly expensive solution also lol.
06-28-2013, 09:29 PM | #9 | |
I just started on my course, but it sure does have some potential. I just need to get rid of all the roots and undergrowth and find some more rocks. | |
06-28-2013, 11:02 PM | #10 | |
| Re: My JK Quote:
It is a bit pricey but well worth it. When I hit second gear it was very surprising! Basically, the tranny and a standard servo is all that is needed. The shift servo does not need to be high torque. It can even be a cheap mini if your worried about space. After all the money I have spent setting my SCX10 up, it was a major improvement. Depending on your gearing, you go from a very slow crawl to maybe 18 mph. Last edited by Norton; 06-28-2013 at 11:05 PM. | |
06-29-2013, 09:23 AM | #11 | |
Pebble Pounder Join Date: Oct 2009 Location: Australia
| Re: My JK Quote:
07-03-2013, 02:54 AM | #12 |
So it turns out that my esc does not have a drag brake. Found that out the hard way when I would let off the throttle and it just came tumbling down more than once. This is the one that my LHS had in stock. My question is, would just a factory axial ae-2 be fine? Everything else is stock for now so I would think so. I don't really see the need for a high dollar one right now. I know down the road I will probably upgrade but my actual rock crawler comes ahead of this thing and I am in the home stretch with that thing so I need all my extra coin I can get for it. |
07-03-2013, 07:42 AM | #13 |
I wanna be Dave Join Date: Nov 2007 Location: roseville
| Re: My JK
I RUN A AE-2 IN MY SON`S YOTA WORKS GREAT! HAS GREAT DRAG BRAKE . GOOD LITTLE ESCPUT A BEC ON IT AND HE RUNS 5000 MAH 3S ON IT
07-03-2013, 01:30 PM | #14 | |
| Re: My JK Quote:
Now I just stopped by my LHS and he can get me an Axial AE-2 for 78.99. Now he has has a Tekin FX-R and 35T combo for $109.99. Would that really be worth the extra $30? | |
07-03-2013, 01:31 PM | #15 |
| Re: My JK
BTW, to the guys who are taking time out to answer all my noob questions, I really appreciate it. I am still learning an awful lot with this thing.
07-03-2013, 01:59 PM | #16 |
Quarry Creeper Join Date: Jun 2013 Location: Escondido, San Diego, CA
| Re: My JK
I have the tekin fxr and 35t combo. Love it, would def recommend it over AE-2, i think the AE-2 sometimes has problems with 3s. The FXR can handle 3s no problem and you can program it with the 2 buttons on the front no PC links required. Plus supppper small footprint. However I have been considering getting a Castle Sidewinder v3 because it's already waterproof. |
07-07-2013, 11:49 PM | #17 |
| Re: My JK
Well I ended up just going with an AE-2 I found on eBay. Paid $50 and the ad said it has been "waterproofed" and the LiPo cut off is for sure there. After I get this installed, I plan to just beat the snot out of the thing until something breaks. I bought this thing to run when I don't get to take my real Jeep and so far they have both been sitting tore apart for the last few weeks. |
