Thread: Is this normal?
Old 07-02-2013, 08:17 PM   #1
Default Is this normal?
I am a noob. So bare with me...
I just got this RC and noticed when I turn either one of the outside tire will turn Really hard. Both wheels do it just only when it is on the outside of the turn Look at pics.
I was told it has VP high steer knuckles, HR one (not sure what "HR one" is)
KennethXJ is offline   Reply With Quote
Old 07-02-2013, 08:20 PM   #2
Default Re: Is this normal?
That is your steering ackerman which is WAYY too much. Back off your endpoints for your servo some.
Lentsnh2012 is offline   Reply With Quote
Old 07-02-2013, 08:25 PM   #3
How bout a pic with ur wheels straight? And maybe one with a pic of ur knuckles?
I don't think the epa has much to do with what ur tie rod and knuckles are doing. Backing off ur epa will only stop the outside from steering in so much, which also stops ur inside tire from steering as well..
It looks like you have too much toe in. So you can simple back off the link ends on ur tie rod a touch and it will stop ur outside tire from turning in so much and will allow ur inside to steer more.
winnerone23 is offline   Reply With Quote
Old 07-07-2013, 04:57 PM   #4
Sorry for long response, I was out of town. Here are the pics you asked for.
I have tried two different tie rod lengths
Old 07-07-2013, 07:47 PM   #5
It looks good from straight on.. hmm.. I still say run it with some toe out.. make you and the steering much happier.
Old 07-08-2013, 12:52 AM   #6
Is it due to flex in the plastic C-Hubs? Mine does this as the servo is too strong....and I haven't set end points.
o0wiz0o is offline   Reply With Quote
Old 07-08-2013, 04:48 AM   #7
the ackerman is reversed. ive seen 90% of Axial axles do it. I can see on your knuckles you have two mounting points. move the draglink to the holes closer to the axle. it will decrease the difference in steering angle between the two tires.
my wraith does it, but only just noticable.
the problem comes from when the drag link is shorter than the distance between the kingpins. so if it was behind the axle, as it is, would be perfect, coz the inner wheel would steer more and thats the way it should be. so for now, as i said, just try it on the holes closer to the axle, and also run some toe out, as Winner said. both will help with steering properly.
Hope that helps.
klampykixx is offline   Reply With Quote
Old 07-08-2013, 07:40 PM   #8
Guys, I really appreciate the advice! I will try all the above and I am looking for some metal chubs also.
Old 07-08-2013, 07:56 PM   #9
You might try swapping the chubs, side-to-side, and see if it makes any difference.
KJ10 is offline   Reply With Quote
Old 07-08-2013, 08:17 PM   #10
not attacking you, but may i ask why you think that might work? swapping Chubs side to side will only change the castor, not the Ackerman.
OP needs new knuckles. they look like the VP hi-steer knuckles, which i think are optimised for BTA (behind the axle) steering, in which case would be IDEAL with it steering the way it is.
infact, KennethXJ might consider mounting the steering system behind the axle, it will work much better that way without having to replace parts.
just reverse the servo horn and knuckles. done.
edit: if it fits.. lol
Old 12-22-2013, 08:59 PM   #11
I hate it when people say your hubs are backward. They are the same. The issue i ran into was it steered harder one way than the other so i adjusted my link off the horn ive reset the horn and ive played with the steering link for tow. And adjusted steering trim on the receiver.
donnielovett is offline   Reply With Quote
Old 12-22-2013, 09:11 PM   #12
Ackerman Steering Principles/RC
video (less reading) Lol
http://youtu.be/oYMMdjbmQXc
TacoCrawler is offline   Reply With Quote
Old 12-22-2013, 09:15 PM   #13
Totally normal for stock steering geometry. Vanquish also has some zero ackerman knuckles which should eliminate the problem.. some have reported clearance issues with stock offset tires though so your results may vary. In any case the steering as is wont hurt anything it will just cause a bit of tire scrub and increase your turning radius.
cruuk is offline   Reply With Quote
Is this normal? - Similar Threads
normal? crawlgranitebay Axial AX-10 Scorpion 7 01-09-2009 10:17 PM
is this normal? slowngreen Newbie General 17 06-12-2008 05:04 PM
is this normal? RcFanatic92 Newbie General 12 02-10-2008 05:03 PM
is this normal? mudboger07 Newbie General 7 01-31-2008 10:44 AM
is it normal....... justintime Axial AX-10 Scorpion 4 11-16-2007 12:27 PM
