07-07-2013, 05:41 PM | #1 |
Newbie Join Date: Mar 2013 Location: Dallas
| Twisted Shaft! |
07-07-2013, 05:47 PM | #2 |
RCC Addict Join Date: Oct 2012 Location: Norcal
| Re: Twisted Shaft!
MIP, Junfac or Punisher drive shafts. |
07-07-2013, 05:52 PM | #3 |
Pebble Pounder Join Date: Nov 2010 Location: Below the snow line
I have been using MIP products for years, and they are tough. Recently purchased a set of junfac for my scx10, have 4 runs so far without issues. Or buy traxxas plastic in bulk.
07-07-2013, 05:59 PM | #4 |
Rock Crawler Join Date: Oct 2012 Location: Casper
| Re: Twisted Shaft!
MIP. Last set you'll ever buy.
07-07-2013, 06:31 PM | #5 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
| Re: Twisted Shaft!
x2 I bought junfacs should have spent the extra money on mips from the start. was running brxl and 13t crawlmaster the d got wore out on the female side. |
07-07-2013, 06:56 PM | #6 |
| Re: Twisted Shaft!
What about doing the WB8 Driveshaft Upgrade? Is it worth it or just go MIP, Junfac or Punisher drive shafts? I hope i can post this link. I didn't see anything in the rules. Axial Racing - WB8 Driveshaft Upgrade |
07-07-2013, 07:22 PM | #7 |
Quarry Creeper Join Date: Dec 2010 Location: USA
I put #12x2" wood screws in the male end of the shaft (your truck came with extras) and cut the head off of it, have been running them in my brushless 3s powered wraith with no problems yet, Just something cheap to try out! |
07-07-2013, 07:28 PM | #8 |
| Re: Twisted Shaft!
Wow - thanks for the quick response. Is this normal for the stock shafts? Should I be looking at something on the truck that may have caused this?
07-07-2013, 07:39 PM | #9 |
| Re: Twisted Shaft!
It is pretty much normal if you are using a higher power motor or have the slipper clutch tightened all the way. The best thing to do at this point is invest in a set of MIPs and crawl on with life. |
07-07-2013, 08:38 PM | #10 |
Rock Crawler Join Date: Aug 2010 Location: Esko
Ha! Looks familiar. If you take a part from the parts tree from the parts bag that came with your kit. The actual garbage part you'd throw a way when all the part are off it. Shave all the tabs off it and shove it in the male part of the shaft. It will keep it from collapsing on itself. Not nearly as tough as MIP , but a free mod that does strengthen the stock shaft.
07-08-2013, 12:06 PM | #11 |
| Re: Twisted Shaft!
preventative... budget fix 6 mm thread-all, cut to the length of the inner male shaft, then inserted and reassembled. (CA glue to insure it stays put) splines should hold up better to reasonable torque loads. |
07-08-2013, 12:37 PM | #12 |
| Re: Twisted Shaft!
The WB8 mod works pretty well if you have done it before you have turned you drive shaft into a Twizzler. I have done it on both my Honcho and Wraith. But once your drive shaft has been Twizzled, is it really worth investing in another set of plastic shafts instead of putting that money towards a set of MIPs? Last edited by k7zpj; 07-08-2013 at 12:41 PM. |
07-08-2013, 01:49 PM | #13 | |
| Re: Twisted Shaft! Quote:
07-08-2013, 06:25 PM | #14 |
Quarry Creeper Join Date: Jul 2009 Location: Dublin,Ireland-Cluj,Romania
| Re: Twisted Shaft!
go for MIP,youll never regret it
07-08-2013, 06:57 PM | #15 |
Is the MIPS for the scx10 a pin through design where it hooks to the trans and diff or just set screws?
07-08-2013, 07:41 PM | #16 |
| Re: Twisted Shaft! |
07-09-2013, 01:38 PM | #17 |
Twisted Shaft! - Similar Threads | ||||
twisted shaft | Rummie | General Scale Talk | 3 | 03-06-2012 09:27 PM |
best way to join a rwvo drive shaft to the output shaft on the axle | TRAV | Kyosho Crawlers | 12 | 01-29-2012 07:37 PM |
Twisted drive shaft repair | AR Fabrication | Axial Wraith | 1 | 01-03-2012 01:58 PM |
Twisted Cells and Twisted Crawlers of Michigan Presents "The BG Warm-up Comp" | twistedone | Michigan | 62 | 05-08-2011 07:58 PM |
mip cvd's twisted off shaft | klaygrover | Axial AX-10 Scorpion | 7 | 10-21-2009 10:41 PM |
