couple scx10 Qs... SO I bought a used scx10 - have been enjoying it a lot. I'm going to paint/built a new rubicon body because the body I got was pretty beat. The original owner had moved the battery forward which seems like a good idea. The rig still seems a bit tippy to me though. Maybe I just turn too fast :-) Q1) Any more tips on stability? Wheel weights? Offset Wheels for wider stance? Drive train is stock except for aluminum rods/shafts. Q2) Dumb Q, but what are the headlight buckets for with the new body? If you're just putting a decal on, what are they for? Current body doesy not have them. Q3) Going on vacation - what one or two spare parts should I take just in case? I'd like to do some waterproofing before I go and will read up on that. Also have new LiPos and charger so should be good there. Thanks in advance for any tips! |
I reccomend a spur gear for a spare part..I always seem to strip that lol |
Re: couple scx10 Qs... Quote:
q2. the light buckets are for if you want to run lights on your body not all body`s have that function with the buckets but most axial body`s do like the honcho`s do q3 what spares. spur gears drive-shafts esc and a servo is what i carry with me at all times as you never know what will happen |
Re: couple scx10 Qs... Thanks for the quick replies! When I was running my nitro savage, I pretty much carried everything to build another truck... lol. At least the scx10 doesn't hit stationary objects as fast. ;-) |
Re: couple scx10 Qs... Spare spur gear, driveshaft, driveshaft set screws and link ends (if it's running aluminum links) and a small box of hardware are always good to have on hand. |
Re: couple scx10 Qs... Screw box. Just screws for random happenings. I've been on the trail and knuckles plop off and etc. Screws and allens if your not going hard. |
Re: couple scx10 Qs... bring extra grub screws for your driveshafts, some loctite, and tools |
