07-09-2013, 02:01 PM | #1 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| twin hammer 2 speed into a dingo
was thinking it might be a cheaper way to go 2 speed.. found a new stock one for 60 bucks. is the tranny going to hold up? this dingo is brushed.. any thoughts? thanks |
07-09-2013, 02:14 PM | #2 |
Rock Crawler Join Date: Feb 2007 Location: Crawling Around
| Re: twin hammer 2 speed into a dingo
Do it. I have a 2 speed in my Dingo build using the AX2, and it's a blast. Great idea!
07-09-2013, 08:03 PM | #3 |
just paid for it. going to give it a try..
07-09-2013, 08:08 PM | #4 |
Rock Stacker Join Date: Apr 2013 Location: NW Washington
Can't wait to see how this works. I plan to do a two speed in my Honcho eventually.
07-09-2013, 10:21 PM | #5 |
Rock Crawler Join Date: Jan 2013 Location: Laguna Niguel
Two speed really makes the scx10's fun ! I have the rc4wd in my truck and love it. Why not just get the tranny that's built for the truck instead of monkeying with a TH.
07-10-2013, 05:19 AM | #6 |
The TH Trans is going to be WAY lighter, that's a major consideration, and in the end, if you use it up front with a transfer case, the thing will work like a dream, the same way I have my SCX setup with the AX2 trans. It's a great option! I'm looking forward to seeing your setup! |
07-10-2013, 06:09 AM | #7 |
RCC Addict Join Date: Jun 2013 Location: Port Saint Lucie, Florida
thinking about doing a 2 speed in my dingo as well Thread tag to see how it goes! |
07-10-2013, 06:43 AM | #8 |
Works great, just dropped it in this weekend. Had to fab an adapter plate, just used some scrap 2mm aluminum. Tucks in there well. Had to lift my CGR body just a hair for the interior to clear. I have the older style shafts and they mated right up - just used double setscrews and some red threadlock. The Wild boars should work as well, need to either drill the outputs for the pin or just use 2 setscrews. Eventually plan to pin mine. |
07-10-2013, 08:09 PM | #9 |
great.. good to know.. i was just going to drill the stock skid
07-10-2013, 09:50 PM | #10 |
| Re: twin hammer 2 speed into a dingo |
07-12-2013, 09:44 AM | #11 |
thats what im going to do
07-15-2013, 04:53 PM | #12 |
Put 20000 mah through since doing the conversion and working like a champ. Did have to use red loctite on the drivetrain setscrews, and havent loosened up since. Does not fit with the jeep body for sure unless you want to hack the interior significantly. No problem with the Honcho style. |
10-06-2013, 09:44 AM | #13 |
i finally did this. drilled the stock skid. counter sunk the screws. i got a new trail hammer tranny with hr steel gears in it for 85.. about 1 hour it was in.. bunch of batteries later.. still fine works good. will get some pics after my trip
10-06-2013, 12:05 PM | #14 |
Rock Crawler Join Date: Jan 2011 Location: Blaine, MN
i would have gone with the AX2 trans just for the fact that the gear ratios are way different compared to the TWH ratios. Also I am running or soon will be running an AX2 trans in my TWH for that fact alone. A good friend of mine made a plate for me so if anyone else wants one it sounds like he might start selling them in the vendor section.
10-07-2013, 08:07 AM | #15 |
just got a used ax2. be my first. see what its like
10-07-2013, 09:14 AM | #16 |
Rock Stacker Join Date: Aug 2013 Location: St. Louis
For a Dingo it looks like a better fit than the ax2...spent a good chunk of time on it this weekend, now going to order some parts. Four point and longer wheelbase are necessary if mounted stock on the skid plate. Beyond the fit and bind issues, rock solid tranny with smooth action. |
10-07-2013, 11:26 AM | #17 |
yes it smooth..
