07-19-2013, 09:30 PM | #1 |
Quarry Creeper Join Date: Jan 2013 Location: Spokane
| 509 jk build
I've never bought a kit version trail rig for a build so I decided what the hell... We have a comp coming up in August so I picked up a jk kit and am in the process of building it... Let me know what you guys think! Got the chasis built Decided tho got with a tekin fxr and 35t pro hand wound And finally got the body all painted with Chrysler citrus peal metalic |
07-19-2013, 09:36 PM | #2 |
| Re: 509 jk build
Off to good start.
07-20-2013, 02:04 PM | #3 |
| Re: 509 jk build
Thanks man! Made some progress today! Body is all trimmed flares and roll cage on and top is painted and windshield is painted. |
07-20-2013, 02:51 PM | #4 |
RCC Addict Join Date: Sep 2011 Location: Peoria, AZ
| Re: 509 jk build
That's a sweet color you got going on that JK.. |
07-20-2013, 03:38 PM | #5 |
| Re: 509 jk build
Thanks! I changed the roof up a little bit to try to break up the green. |
07-20-2013, 07:57 PM | #6 |
| Re: 509 jk build
Finally have it all together minus electronics! What do you guys think? With it's big brother... |
07-20-2013, 08:18 PM | #7 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
Diggin the color! ! Nice job man, That's a sharp jk
07-21-2013, 03:34 AM | #8 |
Newbie Join Date: Apr 2013 Location: Space Coast
| Re: 509 jk build
Awesome looking Jeep!
07-21-2013, 07:39 AM | #9 |
| Re: 509 jk build
When there is no weight on the suspension and I give it throttle the front axle hops and skips... Does anybody have any ideas why it would do this?
07-21-2013, 08:17 AM | #10 |
Rock Crawler Join Date: Sep 2011 Location: truckee
| Re: 509 jk build
Check your front driveshaft, it might be out of phase.
07-21-2013, 08:19 AM | #11 |
Not sure what you mean by hops and skips...but how is the angle of your driveshaft going into the front axle? Can you post a pic? I've had angles that caused my axle to seem like it was "surging" before. And if I held it up and hit the throttle it acted choppy and cause alot if bouncing while driving it....may be your issue..but I'm just guessing
07-21-2013, 12:26 PM | #12 |
| Re: 509 jk build
I don't know what it was but yes it was surging. I tore the front axle apart am checked everything and it looked fine... I tapped the pinion a little bit down and put it together and it's fine now... Must have been bad mesh.
07-21-2013, 05:53 PM | #13 |
| Re: 509 jk build
Thanks guys! I'm just not a fan of everyday colors and everyone having the same color and body and all that! I was trying to go for a different look!
07-21-2013, 05:58 PM | #14 |
Rock Crawler Join Date: Sep 2005 Location: Columbia, SC
| Re: 509 jk build
looks like your mirrors are mounted to the front cowl instead of the doors, did you mean to mount them there?
07-22-2013, 08:25 PM | #15 |
| Re: 509 jk build
Wiring all done! Finally assembled with painted hubs and all!! |
07-22-2013, 09:24 PM | #16 |
Nice job on that! Turned out good... I like being able to have all the electronics In one spot like yours..if I didn't have an interior in my honcho I'd do something like what you did..keeps the chassis clean looking!
07-23-2013, 06:49 PM | #17 |
| Re: 509 jk build
It's nice because the boxes fit perfectly under the original interior!
07-28-2013, 09:36 PM | #18 |
| Re: 509 jk build
Finally got this thing on the trail with some buddies! It was very impressive! Here are some pictures from our little trail session. |
07-29-2013, 07:29 AM | #19 |
| Re: 509 jk build
I only had one issue.... The pinion on the motor slipped off the spur and two tranny screws came loose and fell out but everything is back up and running on the trail!!!
07-29-2013, 08:08 PM | #20 |
| Re: 509 jk build
Made a trade last night for an old jk body to a buddy for a set of new mip cvd's! Got them installed tonight and everything tightened back up! |
509 jk build - Similar Threads | ||||
Jeep scaler build and comp micro crawler build | droopmodmrc | Losi Micro-Rock Crawler | 1 | 12-25-2012 12:34 PM |
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ | 53 willys | General Crawlers | 108 | 11-28-2011 12:42 AM |
Grappler Body Trimming. How much off the rockers? 509 Media | 509 Media | Paint and Body | 7 | 12-15-2009 09:42 PM |
RcBros LCC Build, Hi-Res pics & More Build!! | RcBro | Team Losi Comp Crawler | 30 | 06-03-2009 07:26 PM |
