07-21-2013, 12:20 AM | #1 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
| my f-250 super doodie
i recently traded with Tncrawler for a honcho roller he had. It had the basic mods/upgrades most would do. here's a quick rundown of what it has on it now.. mip shafts rrp output gear in tranny delrin lower links aluminum steering links aluminum knuckles 3racing winch/heyok winch controller and a rolandrockshop winchline kit hitec 5645mg servo mmp esc with a cc 10a bec (set to 6.5v) trinity epic D3 13.5t sensored brushless motor proline ford f-250 cab/honcho rear bed dinky r/c honcho interior 1.9 axial wheels with r35 trepadors and mthead rings that's it for now..i'll add more as i upgrade it..on to some pics.. here's what it looks like now.. waiting on the treps and axial wheels.. i mounted the winch to the top of the bumper mounts.. the body goes right up to where the bumper starts..so there's some room in between the winch and body. and the mounting holes for the winch are exactly the same width as the bumper mounting holes..worked out perfect.. i drilled a hole in the center of the bumper, and glued a piece of antennae tube in it for my winchline to run through.. i got my winchline kit and the delrin fairlead from Josh at Rolandrockshop that's all for tonight...more pics on the interior and other parts of what i've done to it tomorrow |
07-21-2013, 09:19 AM | #2 |
| Re: my f-250 super doodie
this truck came with a dingo bumper that had been cut. so one of the first things i had planned was to fill the sides in.. i had some material laying around that matched perfect with the texture of the dingo bumper..i cut the pieces to shape and attached them.. then i got this dinky r/c interior from another forum member..it was already painted and i didn't mind the colors at all..so i began to assemble and trim it up.. here's some shots of it installed..it fits pretty good..just a small gap up under the windshield in front.. and here is a pic showing the gap up under the windshield..can't be noticed unless you look in like i id for the picture.. my plan is to get some weather stripping foam, and place it in the gap..should seal and fill it nicely.. and here's my electronics lay out..nothing permanent..but it works for now.. and my motor... that's it for today.. i'll post a pic of the wheels and tires when they arrive and get mounted up..thanks for looking.. |
07-21-2013, 05:58 PM | #3 |
Newbie Join Date: Aug 2012 Location: Gloversville
Sweet looking truck, im thinking about buying a winch but was just wondering if the winch will work with the stock radio that comes with the honcho?
07-23-2013, 04:08 PM | #4 |
got my wheels and tires from Tncrawler !! mounted them up.. |
07-23-2013, 04:27 PM | #5 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
you said doodie.... |
07-23-2013, 04:31 PM | #6 |
Quarry Creeper Join Date: Jun 2013 Location: Tacoma
looks good in silver! I decided to go with a dual paint job on mine. |
07-23-2013, 04:51 PM | #7 | |
Rock Stacker Join Date: Apr 2013 Location: NW Washington
| Re: my f-250 super doodie Quote:
The stock radio is only a two channel. I think the only way to do it would be to hook it into your steering with a switch. Then you would use the steering wheel to control it and switch between steering or winch. I use the Bulldog winch with the fob for now. Eventually I'll get a radio with more channels and then get a controller. | |
07-23-2013, 08:31 PM | #8 |
The cab came painted when I got it.. I was thinking of spraying the bottom part of the doors and curve around the fender with some textured black.. to appear as if it were lined with something. But not sure on that yet... I'm also gettong some crawler innovations foams for my trepadors..I really like these tires, they were on my unimog and worked very well...
07-23-2013, 09:46 PM | #9 |
RCC Addict Join Date: Feb 2012 Location: Ca.
I like your interior, the weather strip should work well between the dash and wind shield. I'm using a 3racing winch and an RC4WD wireless remote, just change/splice the plug that goes from the winch to the wireless controller.
07-24-2013, 03:12 AM | #10 |
| How's that working out...the guy I knew who had one always seemed to have to be kinda close to operate his woth the key fob controller. What are you powering your winch off?
08-28-2013, 07:33 PM | #11 |
Been a little while, not alot of changes.. I got some axial cvd's for the front axle, and got a tighter turning radius.. I'm in the process of trading the mmp/13.5t for a Holmes Hobbies brxl/35t combo..the more I drove it I realized I didn't need the crazy speed out of the brushless setup..and I figured the brushed motor could handle the water/mud I may encounter at our upcoming G6... I did trim more of the bottom of my interior so I could relocate my battery where my esc/rx was...also got that plate lowered down about 1/4" ..now I'm racking my brain trying to decide where to put my esc/rx...I'm thinking possibly on top of each slider, esc on one side and rx on the other..I'm thinking of grabbing the vanquish products slider mounts and the electronic plate that they have that mounts to them.. I've got enough clearance under the interior for them to fit...but it seems I'm never happy with where I put things..haha..I'll get some more pics up when I get the new esc/motor.
08-29-2013, 03:20 PM | #12 |
Quarry Creeper Join Date: Jul 2013 Location: Toronto
truck looks good...love that F250 body
08-29-2013, 03:48 PM | #13 |
thanks , it's coming along.. my pro line powerstroke scale shocks came in the other day.. so i got them mounted up. i like the look and stance they gave it.. it sits just a little bit lower..hardly noticeable to most.. but i like it.. that's it for now.. when my esc/motor comes n i'll get to work finding a spot to mount it.. i'm gonna be looking for some stuff to waterproof the esc/rx this weekend and i'll be picking up some things to get my g6 scale items made up.. |
08-29-2013, 04:14 PM | #14 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
Haha, you said doodie! Sent from my HTC Desire HD A9191 using Tapatalk 2 |
09-05-2013, 08:53 PM | #15 |
So I got my hh brxl and motor the other day..and It's the waterproof version..so that was a plus, and I picked up some acrylic conformal coating in a spray can... I used it on my futaba rx and my sons spektrum rx tonight. I'll test them tomorrow. But here is a pic of mine with 4 coats on it.
09-07-2013, 09:17 AM | #16 |
here's a short video of my futaba rx i'm using for this truck. i applied 4 coats of acrylic conformal coating to it.. Futaba 4pl waterproofed receiver. - YouTube |
09-16-2013, 09:56 AM | #17 |
i recently ordered a Crawler-Dad 2" version2 led light bar. to help me get through the night stage of our upcoming Swine Swagger G6. i received it saturday but wasn't able to try it out till sunday. upon trying it out i relized only 3 of the 6 leds were working..here's a shot on 7.4v (11.1 blinded me even with only 3 leds lit up ) i got ahold of Crawler-Dad and we worked it out and i shouls soon have a new strip to put in my housing. but in the meantime i managed to get the housing mounted..here's some shots of that...don't mind the crooked looking body..lol.. once i get my new led strip and hook it up i'll get some pics in the dark...very excited to see how bright it is with all 6 leds lit up !! |
09-16-2013, 08:46 PM | #18 |
Rock Crawler Join Date: Jun 2013 Location: Cincinnati
Im digging the light bar on the bumper man, it just "fits" that truck.
09-16-2013, 10:13 PM | #19 |
09-19-2013, 04:25 PM | #20 |
Got my new led strip today! Cannot be happier with the help and service I received from Marc at Crawler-Dad leds... I'll get some night time pics later... |
my f-250 super doodie - Similar Threads | ||||
- Project: F-250 Super Duty - | Dr. Kustom | Micro Scale Rigs | 22 | 04-25-2012 09:03 PM |
F-250 super duty | RoadKing | Paint and Body | 2 | 06-10-2010 07:55 PM |
Super-Duty F-250 | RoadKing | Chit Chat | 5 | 07-11-2009 08:59 AM |
Pro-Line Ford F-250 Super Cab | NoblesvilleKid | Paint and Body | 21 | 02-25-2008 11:26 AM |
