07-21-2013, 04:06 PM | #1 |
Pebble Pounder Join Date: Mar 2013 Location: ringgold
| Need help plz
I have had my scx10 for a while now and I need something to make it a little better on the trail with a little bit of crawling thrown in. I have a winch, 2s lipo, 55t axial motor, stock esc. Rc4wd 1.55 Irocks and steelies. I mostly trail and climb a dirt pile near my house. What can I do to help the truck perform better. The only thing is I only thing is all I have is $50.
07-21-2013, 04:19 PM | #2 |
Quarry Creeper Join Date: May 2010 Location: scotland
| Re: Need help plz
have you weighted the wheels as you don`t say it should help you with climbing another thing is 4 link the rear it will help with articulation other than that you seem to have a good rig for what you want it for
07-21-2013, 04:41 PM | #3 |
Quarry Creeper Join Date: Jan 2013 Location: Spokane
| Re: Need help plz
If it were me I would run like a 35t motor and 4 link the rear
07-21-2013, 05:01 PM | #4 |
It's 4- linked front and rear and their is weigh on the chassis bc last time I weighted my wheels it ate my berings and I have a weighted set of 2.2 mashers with no foams and holes in the rims
07-21-2013, 07:04 PM | #5 |
Rock Crawler Join Date: Jan 2013 Location: Laguna Niguel
| Re: Need help plz
For less than $50 I'd get a set of overdrive gears for the front of your rig. It'll help your climbing performance and turning radius
07-21-2013, 08:22 PM | #6 |
Rock Crawler Join Date: May 2012 Location: Columbus
| Re: Need help plz
i over drive front and rear an run 15t 2s i found my joy
07-21-2013, 09:28 PM | #7 |
Quarry Creeper Join Date: Apr 2011 Location: Canada
| Re: Need help plz
Id say the mashers are holding you back, that's not really a scale or crawling tire. If your went to something else like irok interco or rover or anything else that is a soft compound truck tire it would probably perform better.
07-22-2013, 07:14 AM | #8 |
I normally run I.55 irocs the mashers are for crawling
07-22-2013, 07:52 AM | #9 |
RCC Addict Join Date: Feb 2012 Location: UK
| Re: Need help plz
Have you done any mods to it? Moved the battery etc?
07-22-2013, 10:14 AM | #10 |
The batt is sideways across the chassis and I also have 2 plasti-diped d size batts on each side of the chassis
07-22-2013, 10:17 AM | #11 |
| Re: Need help plz
What area do you want to improve? Better Crawling? Better trailing? I imagine the two biggest limitations of your rig are that 1.5's don't leave much ground clearance and that a 55t motor is a little slow?
07-22-2013, 11:01 AM | #12 |
The 1.55 are 4.33 and 1.9 flat irons are 4.25 and would a 35t give me more speed and keep the same torque and run time
07-22-2013, 11:32 AM | #13 |
| Re: Need help plz
I run the stock 27t with a 14t pinion. My mate runs 27t with 16t pinion. I prefer his. He has a little more speed than me which helps him get up some slopes I seem to run out of steam on (Theses are slopes where traction is a issue - Silt etc). I think my truck is a bit heavier than his though. They both have a lot of torque and low end control still and climb like goats.
07-22-2013, 02:44 PM | #14 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
What are the d batteries for? Sent from my ZTE V768 using Tapatalk 2 |
07-22-2013, 05:01 PM | #15 |
Pebble Pounder Join Date: Apr 2012 Location: Canada
I just installed a 17 turn reedy motor it's got a bit of speed and it still crawls well
07-22-2013, 05:04 PM | #16 |
I also have a 35t atomic for when I want to slow it down
07-23-2013, 05:18 PM | #17 |
The d batts are weights. Getto but works good and I run a speed pack 2s 4500 mah
07-23-2013, 06:37 PM | #18 |
| Re: Need help plz
When I got my first scx the first things I did were esc 35t motor shocks and tires and weighted the wheels... I will say changing the motor from a 55t to a 35t probably made one for the biggest differences just because I had the when speed to get up a lot of the trail.
07-29-2013, 11:43 AM | #19 |
| Re: Need help plz
so a 35t would help cuz i know sometimes i run out of steam when going up hills on the trails
Need help plz - Similar Threads | ||||
..Help plz | maxstone16 | General Crawlers | 9 | 08-17-2012 02:33 PM |
Little Help Plz | Dukeboy | HPI Wheely King | 1 | 11-13-2008 12:06 AM |
help plz | bodybags101 | Chit Chat | 17 | 12-15-2007 04:16 PM |
help plz | bodybags101 | Newbie General | 5 | 12-11-2007 10:32 PM |
help plz | bodybags101 | General Crawlers | 14 | 12-03-2007 06:59 PM |
