08-12-2013, 08:34 AM | #1 |
Newbie Join Date: Aug 2013 Location: Charelston
| Axle distance measurment
Hey guys I am doing a custom build but I'm using scx10 guts. I don't have the trans or drive shafts yet just the suspension. Can anyone tell me the distance between the axles from axle to axle? Thanks again guys.
08-12-2013, 08:40 AM | #2 |
| Re: Axle distance measurment
Also, if anyone has a trans and drive shafts for the scx10 or wealth lmk I'm looking for a cheap (stock) trans and drive shafts or just trans.
08-12-2013, 03:56 PM | #3 | |
Rock Crawler Join Date: Jul 2011 Location: Placer County
| Re: Axle distance measurment Quote:
you mean the wheelbase? depends on which body you're putting on the rig, and whether or not it's just the cab/flatbed in which case the rear can be placed wherever you want. anywhere from 10-18" is what i've seen on custom SCX10 builds. the only real limit is with a super short wheelbase under 11" since you still have to have good driveshaft working angles (but even then you can clock the axles and c-hubs to help it out). | |
08-12-2013, 09:01 PM | #4 |
Dingo wb os 11.3" and honcho/jeep jk is 12.4". That said any wb is possible.depends on the body. For driveshafts pick up some Mips, they will be the last ones you need to buy again. I have used traxxas yokes and shafts, but fot $15 -$20 more you can have the mips.
08-12-2013, 09:22 PM | #5 |
Rock Crawler Join Date: Oct 2012 Location: Casper
Even my Slash 4x4 has MIPs. Just get them. Never worry about drive-shafts again.
08-12-2013, 09:32 PM | #6 |
Let the distance be determined by the body being used. Build the wheelbase to look correct under the body.
08-13-2013, 04:40 PM | #7 |
Wheel base is considered the width from what I thought. But I get what you guys are saying. I just wanted to see how extendable the standard drive shafts are. I should have a sXC10 locked tranny coming my way soo. I just didnt want to mess up the axle distances.
Axle distance measurment - Similar Threads | ||||
Leaf Spring Measurment?? | Easymoney | Tamiya Txt-1 and Juggernaut | 2 | 10-14-2007 12:17 PM |
need the steering linkage measurment for RWS | quads4_life | Axial AX-10 Scorpion | 13 | 09-28-2007 11:56 PM |
distance in clod axle | pedro | Tamiya Clod Buster | 1 | 09-02-2007 03:59 PM |
need quick axle measurment | TxCruzr | Tamiya TLT Crawlers | 2 | 09-11-2006 10:55 PM |
Need quick tire measurment... | ScaleHobbies | General Crawlers | 2 | 08-01-2006 05:03 AM |
