08-14-2013, 12:22 AM | #1 |
Quarry Creeper Join Date: Jan 2011 Location: vincennes 2 hours south of indianapolis
| Rear axle sounds like gears stripping
My son was driving his rig today and out of nowhere it sounds like gears in rear axle are grinding. I take it apart and everything looks fine has grease and all. I guess my question is is it possible for the gears to be toast in it? It is a rubicon rtr completely stock other than some steering upgrades and running 2.2s
08-14-2013, 12:50 AM | #2 |
RCC Addict Join Date: Feb 2012 Location: UK
| Re: Rear axle sounds like gears stripping
Disconnect the drive shaft and see how freely it spins. |
08-14-2013, 04:23 AM | #3 |
Pebble Pounder Join Date: Apr 2012 Location: Canada
Look closely at the teeth on the rear pinion gear my wraith did the same thing ended up slightly rounding the teeth off
08-14-2013, 05:03 AM | #4 |
RCC Addict Join Date: Feb 2012 Location: Ca.
The noise may not be coming from the rear. Take a look at your motor pinion and spur gear.
08-14-2013, 06:06 AM | #5 |
Rock Crawler Join Date: Sep 2005 Location: Columbia, SC
My locker broke its little tabs and was slipping in the plastic housing and it sounded like that. If the gears look good open up the carrier. Sent from my DROIDX |
08-14-2013, 08:05 AM | #6 |
Go ahead and epoxy the locker into the carrier and shim the pinion .
08-14-2013, 01:16 PM | #7 |
Ok I'm almost positive it is the rear axle cause you can see it sort of bouncing when it does it. I tried shims with the same result. Ill take it apart when I get home and check the locker
08-14-2013, 07:44 PM | #8 |
Ok so it spins freely. I disconnected and it know longer does it. I took it back apart and locker is fine but teeth on ring look slightly rounded on the edge. Is there a way to shim the pinion in to ride the teeth deeper into the ring.
08-14-2013, 07:49 PM | #9 |
| Re: Rear axle sounds like gears stripping Your last post said you already shimmed it?
08-14-2013, 11:04 PM | #10 | |
| Re: Rear axle sounds like gears stripping Quote:
Has me thinking your drive shaft was out of phase... misaligned drive shafts make the axle(s) jump due to imbalance. My son had this issue with his honcho after disassembling the axle from the chassis. There are alignment marks on both outer ends of the drive shafts. My son failed to realize this. If those are ground down or can't be found... align the pin(s) at both ends of the DS's, at the trans./axle output shaft. Besides this issue... my son thought there was something wrong in the transmission... sounding like a bad gear mesh... Turns out it was simply one of the pins holding the driveshaft near the transmission cover had backed out slightly... This was rubbing against the trans. cover sounding like booger'd gears. Nope... but a little locktight on the thread of that pin... would likely keep those from backing out. | |
08-15-2013, 03:04 AM | #11 |
Yes I did shim it just figured I'd get some opinions on it.
08-15-2013, 03:05 AM | #12 |
Went through everything also and everything seems fine except slightly rounded teeth
08-15-2013, 03:35 AM | #13 |
08-15-2013, 06:18 AM | #14 |
I know I'm gonna get flamed for suggesting integy parts but I've had good luck with these front and rear and no locker to deal with http://www.integy.com/st_prod.html?p...4#.UgzGyzK9Kc0 |
08-15-2013, 06:27 AM | #15 | |
Quarry Creeper Join Date: May 2010 Location: scotland
08-15-2013, 06:30 AM | #16 | |
Sent from my DROIDX | |
08-15-2013, 06:40 AM | #17 |
I meat the ring and pinion and the bonus of that is you get a solid locker I live in Canada and I didn't pay that price |
08-15-2013, 07:07 AM | #18 |
| Re: Rear axle sounds like gears stripping |
08-15-2013, 02:33 PM | #19 |
I used a washer from a set of 2.2 wheels to shim and it almost seemed like it was to much but still did it. I completely disassembled the axle and all looked good except for the far outside edge of gear was slightly rounded. I put another complete axle I have for a project I'm working on and it no longer does it. Do you guys have any suggestions for what to use for shims and are really thin so maybe I can fine tune it. I ordered a new set of gears for it even if I don't use them ill have a set just in case. Thanks for the help
08-15-2013, 02:50 PM | #20 | |
Did you open the carrier and check the two tangs on the locker? | |
Rear axle sounds like gears stripping - Similar Threads | ||||
Broken rear axle gears | motojeep | Axial XR10 | 9 | 04-18-2013 09:28 AM |
front and rear different - Bully Axle motor pinion gears | vodka child | Newbie General | 0 | 04-13-2010 02:10 PM |
reverse is gone, sounds like gears are stripped, but their not? | traxxas4fun | Tamiya XC/CC01 | 11 | 11-19-2009 04:38 PM |
