08-20-2013, 02:49 AM | #1 |
Newbie Join Date: Jun 2013 Location: Hawaii
| Vanquish links help.
So I installed a vanquish titanium link which include top bottom and Y link replacement. I notice my trucks wheelbase is much longer then stock. My problem is the body touches the tires. Have anyone else have this problem? What should I do to make it not touch the body? I'm using a proline jeep Cherokee for my rig. Thanks in advance. |
08-20-2013, 04:38 AM | #2 |
Quarry Creeper Join Date: Nov 2012 Location: Michigan
| Re: Vanquish links help.
did you get the right wheels base links? the honchos links make the wheel base around 12.4 and the dingo wheel base is around 11.4 if im not mistaken. you may have gotten the wrong length links.
08-20-2013, 10:08 AM | #3 |
Newbie Join Date: Jun 2012 Location: Indianapolis
I had the same problem. I got the honcho links and after install my wheelbase is just shy of 13 inches. I just cut my the wheel wells to make it fit.
08-20-2013, 01:58 PM | #4 |
Pebble Pounder Join Date: Oct 2008 Location: Oshawa, Ontario Canada
I have them on my rig, I had to use both Revo & the longer Jato rods ends to make my wheel base but my rig was just a bit longer then a stock Honcho. I think I used 4 100mm links up front with Revo rod ends on both upper links and a Revo and a Jato on ech end of the lowers,the rears were 110mm up top with a Revo and a Jato rod end,and 120mm on the lowers links with a Revo and a shortened Jato rod end. My wheel base sits at 12.63" |
08-20-2013, 05:23 PM | #5 |
I joined the Band! Join Date: Jun 2008 Location: Sacramento
| Re: Vanquish links help. |
08-21-2013, 03:56 AM | #6 |
Thanks for all the replies. I love the wheel base for crawling so I'm going to keep the same set up and just run dingo flares on the Cherokee. I kinda had a hunch that the links were for the curries, guess that's on the wish list in the future. |
08-22-2013, 07:15 AM | #7 | |
Newbie Join Date: Jul 2013 Location: Australia
| Re: Vanquish links help. Quote: Does that mean the the currie vp titanium links will not fit the stock scx10 wrangler? | |
08-23-2013, 06:31 AM | #8 |
can anyone please let me know if the currie links will fit the stock wrangler?
08-25-2013, 02:00 PM | #9 |
I joined the Band! Join Date: Aug 2013 Location: The Hills Of VA
I used the Blue monkey kit. Fits the stock axles fine.
Vanquish links help. - Similar Threads | ||||
Vanquish lower links = M3 or M4? | Soulo747 | Axial Wraith | 3 | 06-18-2012 02:34 PM |
What length vanquish links? | Savage03 | Axial SCX-10 | 3 | 06-05-2012 08:30 PM |
Vanquish Ti links | BIGNASTY | Axial Wraith | 2 | 11-30-2011 09:27 PM |
Vanquish Links? | C_Money | Axial AX-10 Scorpion | 2 | 01-16-2010 11:26 PM |
