08-20-2013, 06:57 PM | #1 |
Newbie Join Date: Jul 2008 Location: Rville
| Help!!!!!!!
Hey I need help please... My scx is is binding hard and will not move and torques up then jumps like something is binding then driving through it but I took the motor and trans off and plug it up and turned freely? Any suggestions?
08-20-2013, 07:03 PM | #2 |
Quarry Creeper Join Date: Aug 2007 Location: Bowling Green KY
| Help!!!!!!!
If the transmission spins smooth what about the axles? Could be a bad bearing or sloppy gears. What about the drive shaft angles? If they're to steep they won't fun smooth. Sent from the tinker room Last edited by xigtc; 08-20-2013 at 07:59 PM. |
08-20-2013, 07:21 PM | #3 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
| Re: Help!!!!!!!
if u lifted rig and/or use mip type shafts, the pins need to be lined up front & rear!!! Had it happen to me when i went to 2.2 & lifted...
08-20-2013, 08:58 PM | #4 |
| Re: Help!!!!!!!
Ok thank you ill try to check out the axles cause the motor and trans free wheeled good
