08-21-2013, 11:00 PM | #1 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| water proof ride
I bought a Traxxas XL-5 speed controller and a traxxas Digital high torque servo..both waterproof; My question now is do I need to do anything to the battery to water proof it or is it ok to get wet/submerged???? Also bought a 17t and 16t motor pinion gear for a little more torque. And also some deans connectors for the esc to battery hook up. |
08-21-2013, 11:03 PM | #2 |
| Re: water proof ride
I forgot...What about the receiver?..is it safe or do I need to do anything special with it?..Also what to do with the axles?
08-22-2013, 04:03 AM | #3 |
Quarry Creeper Join Date: May 2010 Location: scotland
i dont do anything to my batterys and they get wet everytime as for the rx i would either plast-dip it or like i do put it in a balloon then cable tie the top then put some sort of sealant around the top to stop water getting in as for the axles pull them apart and grease the bearing up with marine grease it will help them stop rusting it should also help keep the water out if you put some grease on the outside bearings and if you have any holes in the axle casing like the four on top the front casing get four screws just long enough and put them in
08-22-2013, 05:38 AM | #4 |
Newbie Join Date: May 2011 Location: Park Hills
If your running lipos other than max amps batteries there not waterproof and can be sensitive to large amounts of water.i wrap the seam of the lipo case with electrical tape and silicone around where the wires come out.if your running nimh batteries no worries, go on and bury her deep lol.as for the axles marine grease works well.also if your not running 4 link you'll want to plug the holes on top of the axle housings with screws or silicone.the rx can be double wrapped in a ballon just take the neck of the balloon twist it and ziptie around it well.
08-22-2013, 06:46 AM | #5 |
Newbie Join Date: Jul 2013 Location: USA
Double wrapped balloon for the receiver works great! I've had my Jeep fully submerged and had no issues to speak of.
08-22-2013, 09:47 AM | #6 |
Rock Stacker Join Date: Oct 2012 Location: Mid Coast
Don't forget to hit the servo with some grease as well, the tips on here and the axial blog should help you out. I like to use marine grease for everything, hasn't let me down yet |
08-22-2013, 10:05 AM | #7 |
In case you're not familiar with what dc6278 is talking about - Axial Racing - How to Waterproof your SCX10 |
08-22-2013, 10:57 AM | #8 | |
| Re: water proof ride Quote:
08-22-2013, 11:14 AM | #9 |
| Re: water proof ride |
08-22-2013, 11:35 AM | #10 | |
08-22-2013, 12:08 PM | #11 |
The servo is the traxxas digital hi torque that says its 100%water proof...so I still need to take precautions on this?..was hoping was an install and forget as with the traxxas XL-5 waterproof ESC. The batteries im using are Gens Ace 4000mah 2s batteries which use the external banana plug hook ups for the wires..i may try a balloon on the battery to be safe...For some reason I just picture if water gets between the terminals positive and negative terminals and flow to each other it causing a short. ...and for the receiver I like the balloon method...Thanks for all your help. Does anything need to be done to the axles at all..ive seen where some take them apart and fill the housing with grease..common method? I really don't want to tear the truck all apart as of yet..im going to do minor mods/upgrades keeping the truck as near to stock as I can SO far im just removing the outside shock spacers and changing the motor pinion gear as upgrades. Thanks again everyone..Much appreciated |
08-22-2013, 12:13 PM | #12 | |
08-22-2013, 12:54 PM | #13 | |
08-22-2013, 12:59 PM | #14 |
Pebble Pounder Join Date: Jun 2013 Location: West Jordan, Utah
Glad I read this!! I play around Salt water at one of my spots near the Great Salt Lake....
08-22-2013, 01:07 PM | #15 | |
So I can see the OP is coming from. I kind of doesn't make sense with the whole not mixing electricity and water thing that i've been ingrained with since I was a child. | |
water proof ride - Similar Threads | ||||
water proof? | jseelye | Newbie General | 2 | 03-12-2013 01:38 PM |
Water Proof Me Please | PileDriver | Newbie General | 13 | 04-21-2011 01:06 PM |
What to water proof and how | 0lllllll0 | Axial SCX-10 | 8 | 12-03-2010 03:38 PM |
Water Proof | J-Sizzle | Newbie General | 3 | 01-20-2010 09:14 PM |
water proof ? | CHEETAHRON | Newbie General | 3 | 03-16-2009 01:25 PM |
