08-26-2013, 02:48 AM | #1 |
Rock Stacker Join Date: Sep 2009 Location: Midlands England
| Brushed or brushless
Hello all. Im just getting on scx10 running again it the old kit version that came with the truck body. Looking for a new esc motor combo but not which to use brushed or brushless. Iv been looking at a tekin fxr with a 35t brushed motor and a speed passion reventon with maybe a 17.5t brushless motor.I know the tekin is for crawling but the speed passion has a crawlet profile on it.Also I could use the speed passion for other cars as well with its many different profiles but not sure how good it would be in the scx10 and what its drag brakes would be like.Has anybody used this one in a scx10 at all and how did it work.Is a 17.5t brushless motor the same as a 35t brushed motor.They both work out at the same price for each esc motor combo. Thanks Paul. |
08-26-2013, 09:06 AM | #2 |
Quarry Creeper Join Date: Apr 2011 Location: Canada
| Re: Brushed or brushless
I have seen brushless and brushed on sx10 crawling away, honestly the brushed seems just as good and the tekin combo is actually quite good for the scx10. Brushless always seems like a lot of overkill for a crawler, unless your really looking for speed on flat areas.
08-26-2013, 10:29 AM | #3 |
RCC Addict Join Date: May 2008 Location: Southern,WV
I say it's all up to you, how and where your mostly going to be running it. A good censored motor esc combo can be silky smooth and have great wheel speed.You'll just need to control your trigger finger. But on the other hand. A brushed setup can be nice and smooth but also be water proofed a lot easier. But need more maintenance.
08-26-2013, 10:35 AM | #4 |
I joined the Band! Join Date: Aug 2013 Location: The Hills Of VA
get the tekin rs pro & tekin roc 412.
08-26-2013, 11:37 AM | #5 |
If you mostly do crawling (slow) then you want to go with a brushed motor. If you mostly do trail running (fast) and want to so some crawling, then go with a sensored brushless motor. The SCX10 was designed to run brushed motors so when you run brushless you will break parts such as transmission gears, drive shafts, diff gears/lockers. A brushless setup is going to cost more than a brushed Motor and ESC so you need to have a budget large enough to buy the brushless combo and to buy the upgraded parts. Motor, ESC and upgrade parts you could be looking at the $500.00 range. If I was going to start a SCX10 build today, I would use a HH TorqueMaster 35T or CrawlMaster 16T with HH BR-XL esc. This would be in the $170 range. |
08-26-2013, 01:48 PM | #6 |
Thanks for the reply. Im going to order up a tekin fxr 35t combo.Im in the uk and want to order this from here.The hh do look good but means ordering from overseas and I can order my tekin tomorrow and it will be delivered the next day.Iv always used brushed motors so will stick with them.Used to run my scx10 a while ago but with a very basic esc and 20t motor so looking forward to trying drag brakes.Is it a good idea to order the hotwire pc interface for setting it or will it be ok without it. Thanks Paul |
08-26-2013, 03:05 PM | #7 |
Rock Stacker Join Date: Aug 2012 Location: Portugal
You can program almost everything without. I only use hotwire in fxr to use a curve in throthle, but a lot of people did not like that curve.
08-26-2013, 03:18 PM | #8 |
Pebble Pounder Join Date: Aug 2013 Location: If assholes could fly this place would be a airport
yes they are not steering you wrong.. i would go brushed with rock crawler... motors are cheap and so are the esc...
08-27-2013, 08:40 AM | #9 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
Cheap cheap http://hobbyking.com/hobbyking/store...+car+brushless Sent from my HTC Desire HD A9191 using Tapatalk 2 |
02-01-2014, 11:42 AM | #10 |
Newbie Join Date: Dec 2013 Location: philadelphia
ive gotten some good things from hobby king lol almost all my hell batteries are from there and out of over a dozen only had one puff up but that was when i was learning how to use my i charger
02-03-2014, 05:35 PM | #11 |
Newbie Join Date: Dec 2013 Location: indonesia
Im running a novak goat 3s with sensored brushless ballistic 18.5t and i like the way it crawl, with rc4wd r2 tranny and 20t pinion. But i wanna try HH BR-XL with 35t torquemaster and see the difference
Brushed or brushless - Similar Threads | ||||
Brushed vs. Brushless | goodvibessa | Newbie General | 3 | 01-25-2011 04:39 AM |
Brushed or Brushless?!? | shadowrejects | Non Crawler RC's | 11 | 04-24-2010 03:55 PM |
Brushed vs Brushless | griz2575 | Newbie General | 9 | 04-13-2009 07:06 AM |
Novak Releases "The Goat" brushed/brushless esc and sintered brushless motor | Rockpiledriver | Electronics | 70 | 09-26-2007 05:59 PM |
