Thread: Wraith shocks on SCX 10
Old 09-06-2013, 11:47 PM   #1
Default Wraith shocks on SCX 10
Hey guys.. I obtained a pair of new Wraith shocks... Was considering putting em on my Dingo... Has anyone on here done this... but with really soft springs... cut for a shorter stroke? What brand did yo use?
Chrisnscale is offline   Reply With Quote
Old 09-07-2013, 06:03 AM   #2
Default Re: Wraith shocks on SCX 10
Yes, I've tried stock Axial Wraith shocks on my Dingo chassis. It lifted the truck too much for my liking so I removed them. I ended up with some Junfac 95mm shocks, it was the happy medium.
raceeng18 is offline   Reply With Quote
Old 12-18-2013, 05:55 PM   #3
I have Wraith shocks going on my scx frame too. For 13 bucks for 4 new shocks (eBay) couldn't hardly beat the price.
I will limit them internally with a plastic spacer to minimize the drive-shaft angle and ride height closer to the stock honcho.
Di$c0 is offline   Reply With Quote
Old 12-18-2013, 10:22 PM   #4
yep done with lowering spacers
and the final ride height is not too far from stock
with an improvemnt on the improvised travel ramp
cm4x4nut is offline   Reply With Quote
Old 12-18-2013, 10:25 PM   #5
What's the main advantage to going to these shocks? Increased articulation?
Road1will is offline   Reply With Quote
Old 12-19-2013, 02:48 PM   #6
For me, I wanted to run them really soft and have it all compress under the weight of the truck so it would return back to near stock height. My theory is that I would then get more down travel out of the new shocks/springs and keep the wheels on the ground for longer.
That and they were available for the right price.........
Old 12-19-2013, 05:41 PM   #7
Natedog's Avatar
Way too long a shock for this truck, just buy the proper length shocks.
Old 12-19-2013, 06:19 PM   #8
just put them on and try it. You already have them, what have you got to loose
Old 12-19-2013, 06:53 PM   #9
Natedog's Avatar
Many RTI queens do not do very well off road, but they produce impressive RTI scores.
Old 12-19-2013, 07:24 PM   #10
This is the look im shooting for but ill build it around 103mm shocks....so Wraith shocks shouldnt be a problem unless they leak or big bores limit steering.
Old 12-19-2013, 10:12 PM   #11
Jus
What are you trying to accomplish? They are much bigger than stock shocks in every way imaginable and just don't fit very well. I like the stock shocks, without oil. The suspension is very lively and life like when going over rough terrain. They are also the perfect length (WITH rubber spacers) for the Dingo IMO.
Jus is offline   Reply With Quote
Old 12-24-2013, 10:44 PM   #12
If this is directed at me..... I have a complete frame, axles off a ax10, cab and tires....not a SCX10 kit or RTR. When looking at shocks on ebay the tag line said "Wraith,Rubicon,SCX10,Dingo,Honcho.... just assumed i had a 4 out of 5 chance it would fit..NOT. I could make them work, but looking at all options: Wraith, LOSI Comp, TLT1
