09-07-2013, 08:59 PM | #1 |
Quarry Creeper Join Date: Mar 2013 Location: Wisconsin
| A couple questions |
09-07-2013, 09:16 PM | #2 |
Rock Crawler Join Date: Jan 2013 Location: Laguna Niguel
| Re: A couple questions
Back and fourth movement? I'd guess your truck is 3 linked, yes? If so look at where the link attaches to your axle and there your problem. Just add some washers to stop the unwanted movement. Stock steering sucks, vp high steering knuckles and a custom steering links will do wanders as well as a long enough servo horn. The longer servo horn will give you a few extra degrees of steering. This is what I've done and my steering is crazy good. Oh almost forgot, all the steering improvements won't do swat if you don't upgrade the cvd's to universals because the stock dogbones don't like to turn at tight angles. I got the rc4wd ones and they're great Last edited by Demodude; 09-07-2013 at 09:20 PM. |
09-07-2013, 09:18 PM | #3 |
Quarry Creeper Join Date: Aug 2007 Location: Bowling Green KY
| A couple questions
What's the EPA settings on your radio for the servo? Also looks like you have stock knuckles. If you get high clearance ones that'll help a lot. When you say axles move, does that mean left to right? Sent from tinker room pro |
09-07-2013, 09:19 PM | #4 |
Quarry Creeper Join Date: Jul 2007 Location: Hangtown Ca.
Just from the pic I see that you should try and run your drag link to the furthest knuckle from the servo horn. Maybe try a longer servo horn as well and do you have your end points set up on your radio? What knuckles are you running?
09-07-2013, 09:44 PM | #5 | |
| Re: A couple questions Quote:
Thanks for the information | |
09-07-2013, 09:46 PM | #6 | |
09-07-2013, 09:48 PM | #7 |
| Re: A couple questions I'm running stock knuckles, I'm probably going to replace them and get vp high clearance knuckles
09-08-2013, 12:42 AM | #8 |
I forgot, another trick is to run the link from your servo instead of stock to the short side but instead to the other side making the link longer (you have to make one). In other words, run the link across the midline of the truck (from servo to the right side ) This Improves steering by another few degrees |
09-08-2013, 12:45 AM | #9 |
This is my vid on YouTube Demo's Axial Trail Honcho SCX10 scale build #1 - 1973 Ford Bronco review - YouTube Shows my exact setup |
A couple questions - Similar Threads | ||||
Couple of questions | wrightcs77 | EnRoute Berg | 1 | 06-17-2008 09:04 PM |
couple of questions | RockinRedneck | General Crawlers | 5 | 06-29-2006 02:53 PM |
A couple questions? | em x 6 drifter | General Crawlers | 3 | 05-29-2006 04:18 AM |
couple questions | venom-crawler | Tamiya Clod Buster | 8 | 01-11-2006 09:27 PM |
Couple Questions | Skratch | General Crawlers | 20 | 09-04-2004 10:10 AM |
