09-10-2013, 08:35 AM | #1 |
Quarry Creeper Join Date: Oct 2010 Location: NOR-CAL
| question on servo arm??
I still have the servo from Axial in my JK and was wondering if I could use a longer servo arm and if so which one would be best? Thank you |
09-10-2013, 11:01 AM | #2 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
| Re: question on servo arm??
yes, you can. which one depends on the servo you're using to determine which to buy. many have 2 holes on the arm to choose short or long throw. if you're still running the stock axial servo, then i wouldn't bother with the extra length as the extra leverage will likely burn it up faster, but a metal horn will still be a smart upgrade. what is your desired outcome with the longer servo horn? |
09-10-2013, 11:26 AM | #3 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
Are you trying to get more steering throw? If so, I would only advise doing that if you have upgraded the universals, chubs and knuckles.
09-10-2013, 11:41 AM | #4 | |
To get more steering. Quote:
09-10-2013, 11:45 AM | #5 |
| Re: question on servo arm?? |
09-10-2013, 11:48 AM | #6 |
09-10-2013, 12:52 PM | #7 |
09-10-2013, 01:32 PM | #8 |
Quarry Creeper Join Date: Apr 2013 Location: SE PA
unless you got high clearance knuckles I'm not sure universals will help. I've got alum knuckles that came in my bucket o parts and its the knuckles hitting the axle that limit my steering. currently looking into upgrading to some 8 degree VP knuckles and chubs. just trying to figure out the neede linkage first, and maybe a CMS kit since I will be replacing the link anyways.
question on servo arm?? - Similar Threads | ||||
Servo arm question | HaSharetz | Axial AX-10 Scorpion | 6 | 09-07-2008 08:09 AM |
servo arm Question | Georgerm | General Crawlers | 6 | 07-11-2008 10:05 AM |
servo arm question!! | Wicked_Jester | General Crawlers | 0 | 06-26-2007 05:07 PM |
