09-15-2013, 09:15 AM | #1 |
Rock Stacker Join Date: Sep 2009 Location: Midlands England
| Extending the scx10 wheelbase.
Hello all.I have a scx10 that came as a kit with the truck body from years ago.Im doing it up and would like to alter the wheel base so I can fit the 12.3" proline 4 door jeep body on it.What do I need to extend it is it just longer links underneath it and can I just buy the 4 links without buying the whole upgrade link set.Is it worth fitting a 4 link set and what else should I change at the same time. Thanks Paul. Last edited by Paul1234; 09-15-2013 at 10:01 AM. |
09-15-2013, 11:55 AM | #2 |
Quarry Creeper Join Date: Sep 2010 Location: Gettysburg
| Re: Extending the scx10 wheelbase.
here ya go, this is what ya need to get yours to the honcho wheel base Axial SCX10 TR Aluminum Links Upgrade Set (313mm) |
09-15-2013, 04:47 PM | #3 |
Quarry Creeper Join Date: Mar 2013 Location: Moscow Russia
I'd recommend TopCad or GPM one piece alu links for Honcho (wheel base 12.3"). Cause I had trouble with broken plastic rod ends. On the other hand you will be able to adjust link length with spacers if needed. For now I solved problem using metal rod ends from RC4WD (store.rc4wd.com). They also have various length links.
09-15-2013, 05:28 PM | #4 |
R2J makes stainless steel links that are about the same price as the Axial aluminum link set. The stainless steel slides over the rocks better than aluminum which tends catch on the rocks and uses 4mm rod ends instead of 3mm. http://www.rccrawler.com/forum/chass...-scx-10-a.html |
09-15-2013, 05:53 PM | #5 | |
| Re: Extending the scx10 wheelbase. Quote:
09-15-2013, 08:42 PM | #6 |
Rock Crawler Join Date: Jun 2007 Location: Working in my dream RC workshop and remodeling my entire home.
Or just get some threaded rod and steel brake line and put on some Traxxas rod ends. Get an extra set of drive shafts, too. You'll need to extend them as well. Sent from my Kindle Fire using Tapatalk 2 |
09-15-2013, 08:51 PM | #7 |
| Re: Extending the scx10 wheelbase. Yes, he does. http://www.rccrawler.com/forum/chass...ink-truss.html |
09-16-2013, 10:52 AM | #8 |
Thanks for all the help.Im thinking now of gettng the 2 door jeep as it will fit the wheelbase I have now.Being the older kit it does have alloy links but not 4 linked.Still got the original tyres as not been run much at all just need to sort out a esc and motor. Paul. |
Extending the scx10 wheelbase. - Similar Threads | ||||
Extending The Wheelbase Qs | EEM-CrawlinMachine | 1.9 Scale Rigs | 2 | 02-02-2011 05:20 PM |
I am extending my wheelbase and need drivelines | ScaleReady | Losi Mini-Rock Crawler | 8 | 03-25-2010 09:32 PM |
Extending the wheelbase of a Creeper by 1” | shambrick | Venom Creeper | 2 | 02-15-2010 04:41 PM |
Extending the wheelbase | Got Rocks? | General Crawlers | 7 | 10-05-2005 08:45 PM |
