09-20-2013, 08:25 AM | #1 |
Newbie Join Date: Sep 2013 Location: san antonio tx
| Motor question heat issues
Hey guys I'm new to the forum but have been a follower of y'all's post when ever I've had issues with my rig. But now I'm having heat issues and couldn't find a topic to help, so any way after a while (30mins or so) of trail/crawling It starts to act like it has no power, it couldn't even do a hill climb with the new motor, I'm running a Novak terra claw 35t on 2s with 20/87 gearing and running on 2.2 ripsaws. It's the same gearing I have on my wraith but the wraith has the novak rock star motor and I can crawl all day with it and not have issues. Thanks guys in advance |
09-20-2013, 05:46 PM | #2 |
Rock Crawler Join Date: Nov 2010 Location: the 'burgh'
| Re: Motor question heat issues
Just my opinion...gearing sounds too tall. Go down on the pinion a couple teeth, It'll run cooler and give a little more torque. I'd buy a couple, they're rather inexpensive. I suggest a 16t and 18t and see where your at. |
09-21-2013, 08:01 AM | #3 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
I agree. Good to get a pinion set to mess with gearing. I almost burned up a 35t Integy before I figured out the too tall of gearing. I think I ended up playing with 17tooth and 15tooth and it was much better. The idea is to get the motor spinning faster at low speeds so its more in the power band.
09-21-2013, 08:03 AM | #4 |
Thanks for the help I'll try the other pinions and also is there a performance difference between a sealed can and a rebuildable one?
09-21-2013, 08:56 AM | #5 |
Yes there is, the biggest difference is when your good rebuildable motor starts running like poo, you clean the comm and throw in new brushes and bam, new motor for 6 bucks. |
09-21-2013, 10:00 AM | #6 |
Quarry Creeper Join Date: Apr 2009 Location: Lynnwood
Sometimes just cleaning out the motor on rebuildable motors can make a difference too
09-21-2013, 10:21 PM | #7 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
Something that is overlooked is oiling the bushings after cleaning....just one drop on both ends keeps it running smooth. I ran a 17t pinion using the stock motor and my current custom 27t motor...It barely gets warm after using a full 4000mah lipo 2s pack. I may even try a 16t for kicks and see what happens. Still running the stock 87t spur gear with it. Re-buildable motors are definitely a big difference...If you just get any 27t you may have one with 24 degreed of timing which will give you a lot of speed. You want one specifically designed for rock crawling to get the torque you need..Holmes hobbies, Brood and trinity all offer specific motors. Or you can build your own motor using any 27t armature in a modified canister with an adjustable timing end bell ...That's the route ive taken. |
09-22-2013, 02:26 AM | #8 |
I'm runnin 27t motor with 17/87 it gets warm but driving style will make a difference.
09-22-2013, 08:53 AM | #9 |
Rock Crawler Join Date: Mar 2013 Location: columbus
| Re: Motor question heat issues I have 2 Novak Terra Claw motors and they do not have a fan on the in side. I dont know if that will efect it or not but I would thing it would . The motor sticker all so blocks off 4 holes in the rear of the can you may want to open the holes up to vent heat. |
09-22-2013, 10:28 AM | #10 |
I have a yokomo can that's not vented at all and I notice that the can gets hotter than one with vents in it, swapped it out for a top can with vents, same armature in both cans.
09-22-2013, 12:39 PM | #11 |
Wow thanks for more I put guys I really appreciate it, so I just went out on a trail run and it's about 130-140 but then when I run on a climb it starts to overheat and jumps to 180-190, and I see what you mean greengoblin the vent holes are blocked, I'm going to cut those holes out and put a fan and go out and see what happens
09-23-2013, 01:04 AM | #12 |
Get a pinion set and try and lower the gearing, the gearing is too tall. Weighted tires? Heavier trucks takes more power.
09-23-2013, 02:04 AM | #13 |
| Re: Motor question heat issues |
09-23-2013, 01:28 PM | #14 |
not only weighted tires/wheels, but also larger diameter makes a difference - so if you're running larger than stock 1.9s, like Baja Claws, or some 2.2 tires you will likely need to regear for all that low-speed stuff. same as you would have to do in a 1:1 rig.
09-25-2013, 07:16 PM | #15 |
Ok so today's trail run was epic 3 mile trail slight crawling here and there on the way and the motor only reached 60 degrees, but...........when it came to a hill climb/crawl mainly over some roots and rocks. The fan was acting as if it dropped voltage when I was in a bit of a bind, makes no sense because the fan is connected directly to a different battery? Could it be the resistors that I soldered on the motor??
09-26-2013, 12:55 PM | #16 | |
| Re: Motor question heat issues Quote:
Did you make any changes to it at all gearing wise? Resistors on motors are for glitching problems if I not mistaken..Shouldnt effect power output. Some fans are temp controlled and may spin slow or fast depending on temp. What ESC are you using? what battery? Last edited by 6sharky9; 09-26-2013 at 01:04 PM. | |
09-26-2013, 01:10 PM | #17 |
Quarry Creeper Join Date: Apr 2013 Location: SE PA
don't know how well you know RC's but I burnt out a motor or two by meshing the pinion and spur gear to tightly. I've started useing a papertowel folded in half between the gears and then mash them together. tighten it up with only slight pressure holding them together. spu the spur gear to get the papertowel out. I know other people use a sheet of paper but do it light enough to slide the paper out.
09-26-2013, 08:16 PM | #18 |
| I'm using the stock esc and Ive played with the gears from a 10t-23t pinions and right now I'm using 18/87, and I figured why the fan was cutting out under load, the magnets from the motor where making it cut out, but I think I'm done using sealed motors because today I went out with the wraith on the same trail and hill climb and it has 20/87 gearing and with a 35t rock star motor and same tires. The motor didn't even over heat it was warm to the touch
09-27-2013, 12:38 PM | #19 |
Gear mesh can cause heat too, I usually make the mesh tight enough to put a piece of paper between the spur and pinion and roll the spur with paper in it an not rip the paper.
09-27-2013, 12:58 PM | #20 | |
Ok good...im running a 17 pinion with an 87 spur...I agree the rebuildable motors are far greater than sealed can..Im running a mod 27t and the stock esc with a 2s lipo...Very happy with it..Can build a 27t mod yourself pretty cheap with the right deals. | |
Motor question heat issues - Similar Threads | ||||
mm pro heat issues | csagaz | Electronics | 13 | 05-25-2011 09:21 AM |
Help me solve heat issues | kurt | Non Crawler RC's | 12 | 07-16-2010 01:29 PM |
Still Having Heat Issues - Please Help | JFuel11 | Team Losi Comp Crawler | 14 | 09-18-2009 11:49 PM |
Any heat issues with brushless? | rctoyguy | Team Losi Comp Crawler | 1 | 06-03-2009 03:08 PM |
ESC Heat issues | 801FuNk801 | Newbie General | 6 | 05-01-2009 11:56 PM |
