09-22-2013, 01:30 PM | #1 |
Newbie Join Date: Sep 2013 Location: israel
| Scx10 Dingo Tsl bogger upgrade
Hello My Dingo kit is on the way.... I bought it with tekin fx-r t35, aluminum (c-hubs, rear lockouts, knuckles, upper y arms), 1.9 8 hole beadlock wheels, 15T gear pinion. Now i am thinking about the tires: I saw in the rc4wd the proline interco 1.9 tsl bogger. Is the stocked tires good enough to start with, or this upgrade is worth the 60$? Or maybe i have to change the gear ratio of the axles before i will change the tires? |
09-22-2013, 04:27 PM | #2 |
Rock Crawler Join Date: Mar 2013 Location: columbus
| Re: Scx10 Dingo Tsl bogger upgrade The stock tires work well to be a 4.30". I have a set of the bogers you need to know there taller Height 4.79". The tire is not a bad tire but the stock foams are stiff and the ruber is all so a bit stiff. I found I like the pro line 1.9” TSL SX Super Swamper XL in G8 compound works alot better and is the tire Height is 4.75". pro line all so has it in the stock Height 4.30" size to. This is a photo with the bogers on it. I hope this helps With pro line 1.9” TSL SX Super Swamper XL. Last edited by greengoblin; 09-22-2013 at 05:26 PM. |
09-22-2013, 05:24 PM | #3 |
| Re: Scx10 Dingo Tsl bogger upgrade Tire 1 Axial 1.9 ripsaw tire size 4.30" Tire 2 Pro-Line Interco TSL SX Super Swamper 1.9" tire size 4.30" Tire 3 Rc4wd Interco Super Swamper 1.9 TSL/Bogger tire size 4.79" Tire 4 Pro-Line Interco TSL SX Super Swamper XL 1.9" tire size 4.75" Tire 1 Axial 1.9 ripsaw tire size 4.30" Tire 2 Pro-Line Interco TSL SX Super Swamper 1.9" tire size 4.30" Tire 3 Rc4wd Interco Super Swamper 1.9 TSL/Bogger tire size 4.79" Tire 4 Pro-Line Interco TSL SX Super Swamper XL 1.9" tire size 4.75" Tire 5 Pro-Line Interco TSL SX Super Swamper 2.2 tire size 5.40" |
09-22-2013, 06:22 PM | #4 |
RCC Addict Join Date: Sep 2011 Location: Peoria, AZ
You'll definitley like this set up better. I'm running them on my JK gives you alot of ground clearance and they perform pretty good at crawling or whatever you throw at them. Tire 4 Pro-Line Interco TSL SX Super Swamper XL 1.9" tire size 4.75" |
09-24-2013, 07:04 AM | #5 |
Newbie Join Date: Mar 2011 Location: tracy city
You having any trouble mounting the sx to the double bead lock?
09-24-2013, 08:05 AM | #6 |
Rock Crawler Join Date: May 2012 Location: Columbus
i wanna see a side by side of theses with pits
Scx10 Dingo Tsl bogger upgrade - Similar Threads | ||||
2.2 rok lox vs 2.2 tsl/bogger | scrap value | Tires and Wheels | 7 | 11-25-2011 08:43 PM |
My SCX-10 w/ TSL Bogger | jfred83 | 1.9 Scale Rigs | 2 | 04-17-2011 10:05 PM |
tsl bogger | 904crawler | Tires and Wheels | 1 | 12-26-2010 12:07 AM |
